Linear Transformation questions about dimensions
4 replies · 2K views
potmobius
1. Say you have a linear transform from A to B, and where A has a higher dimension than B. How do you show that the kernel of the transform has more than one element (i.e. 0)? Also, if B has a higher dimension than A, then how to show that the transform isn't surjective?
2. The attempt at a solution
By showing that the kernel has more than the element 0, I want to show that the transform isn't injective. But I'm not quite sure how to get there just by using the fact that A has a higher dimension than B. Is that a good way(as in, not too complicated) of proving it? Any ideas?
For the other part, it makes sense intuitively, since the basis of A will have less elements than the basis of B, so there shouldn't be a surjection. But how do you proceed from there to show that the image of A is a proper subset of B?
Think of the theorem that says the dim(A)=dim(Ker(f)) + dim(Im(f)), where f:A->B is a linear morphism (transformation)
Thanks! Now I feel really stupid for not considering Rank-Nullity before asking this...
You're welcome. I feel stupid for not knowing that theorem has a name ...
Do you know any bad math jokes related to this?
