Linearly Independent Sets After Subtraction
14 replies · 3K views · last reply
Kreizhn
Here is a really simple lin.alg problem that for some reason I'm having trouble doing.
Assume that [itex]\left\{ v_i \right\}[/itex] is a set of linearly independent vectors. Take w to be a non-zero vector that can be written as a linear combination of the [itex]v_i[/itex]. Show that [itex]\left\{ v_i - w \right\}[/itex] is still linearly independent.
For some reason I'm quite stuck on this. My first goal was to let [itex]b_i[/itex] be such that we can write
[tex]w = \sum_j b_j v_j[/tex]
and then consider the sum
[tex]\sum_i a_i (v_i-w) = 0 [/itex]<br /> and show that each [itex]a_i[/itex] must necessarily be zero. Substituting the first equation into the other yields<br /> [tex]\begin{align*}\sum_i a_i (v_i - \sum_j b_j v_j ) &= \sum_i a_i - \sum_{i,j} a_i b_j v_j \\<br /> &= \sum_i \left( a_i - \sum_j a_j b_i \right) v_i <br /> \end{align*}[/tex]<br /> where in the last step I've switched the indices in the double summation. By linear independence of the [itex]v_i[/itex] it follows that <br /> [tex]a_i = \sum_j a_j b_i[/tex]<br /> but that's where I'm stuck.<br /> <br /> It's possible that I'm doing this the wrong way also. Any help would be appreciated.[/tex]
Note that it may be necessary to add that [itex]w \neq v_i[/itex] for any i.
You are given that the set {v1, v2, ..., vn} is linearly independent, which means that the equation
c1v1 + c2v2 + ... + cnvn = 0 has only the trivial solution.
Now look at the equation a1(v1 - b) + a2(v2 - b) + ... + an(vn - b) = 0, where b != 0, and b != vi, and show that this equation has only the trivial solution.
Hey Mark,
Thanks for the reply. This is exactly what I did in "My attempt at the solution," though I got stuck. Do you have any advice on whether I should take a different approach, or how to resolve where I got stuck?
Kreizhn said:
Hey Mark,
Take the case of two vectors {v1,v2}. Let w=(v1+v2)/2.
Okay, so in this case we get
[tex]\begin{align*}<br /> a_1(v_1 -\frac12 v_1 -\frac12 v_2) + a_2(v_2 - \frac12 v_1 -\frac12 v_2 ) &= \frac{a_1}2 (v_1 -v_2) + \frac{a_2}2 (v_2 - v_1) \\<br /> &= \frac12(a_1-a_2) v_1 + \frac12(a_2-a_1) v_2<br /> \end{align*}[/tex]
By linear independence of [itex]v_1,v_2[/itex] we get that [itex]a_1 = a_2[/itex]. Why does this imply that either is zero?
You are staring too hard at the ai's. v1-w=(v1-v2)/2, v2-w=(v2-v1)/2. (v1-w)=(-1)*(v2-w). They aren't linearly independent. I'm saying your proposed theorem is false. That's why you are having a hard time proving it.
Okay, so then that hypothesis goes out the window.
Tell me, does it then make sense to instead say that if [itex]\left\{ v_i \right\}_{i=1}^d[/itex] span a d dimensional space, then for w a linear combo of the [itex]v_i[/itex] it follows that [itex]\left\{ v_i - w \right\}[/itex] span a d-1 dimensional space?
No. The {vi-w} are 'usually' independent, if you pick some random w. But for a family of special values of w it will fail.
See, here's the issue. I've tried to make it simple so that it doesn't complicate things, but maybe putting it in a proper framework will make it better.
Consider a finite dimensional complex Hilbert space [itex]\mathcal H[/itex] of dimension d, and fix an orthonormal basis [itex]\left\{ e_i \right\}[/itex]. Let [itex]P_i:\mathcal H \to \mathcal H[/itex] represent projection operators taking each element of [itex]\mathcal H[/itex] to the one dimensional space spanned by [itex]e_i[/itex]. In particular then, the set of [itex]P_i[/itex] span a d-dimensional subspace of [itex]\mathcal B(\mathcal H)[/itex], the set of bounded linear operators on [itex]\mathcal H[/itex]. Furthermore since the [itex]P_i[/itex] decompose [itex]\mathcal H[/itex] into a direct sum of the orthgonal subspaces, it follows that
[tex]\sum_{i=1}^d P_i = \text{id}[/tex]
where id is the identity operator in [itex]\mathcal B(\mathcal H)[/itex]. I now have a paper in front of me saying that the set [itex]\left\{ P_i - \text{id} \right\}[/itex] spans a d-1 dimensional subspace of [itex]\mathcal B(\mathcal H)[/itex] and I am not certain why this is true.
Clearly, I was wrong to cast this into a simplified framework. So I'm wondering, do you see why these new projectors span 1-less dimensional space?
No I don't. Take the case d=2. Then the set is {P1-id,P2-id}={-P2,-P1}. Looks to me like the span is the same as the span of {P1,P2}. If it were {Pi-id/d} then I can see where the dimension of the span would drop. That's the example I just gave you.
Thanks Dick, you've been quite helpful.
I checked this too, and in the case when [itex]\mathcal H = \mathbb C^d[/itex] and the orthogonal basis is taken to be the standard basis, this always seems to be the case.
I think then that maybe the author is stating that [itex]d-1[/itex] is all that is necessary to do their work, even though the span is a d dimensional space. So alternatively, with this specific set-up can we say that the [itex]\left\{ P_i - \text{id} \right\}[/itex] are linearly independent and hence span a d-dimensional space?
This is where the original problem came from and combined with checking the simple cases I assumed this is why it had to be true. Any thoughts on this one?
Sure, sum {Pi-id} for i=1 to d, you get id-d*(id)=(1-d)*id, right? So id is in the span (except for the silly case d=1). Pi-id is in the span. So (Pi-id)+id=Pi is in. So all of the Pi are also in the span. Hence span has dimension d. Perhaps they are just trying to make a statement that includes d=1??
