- 7,526
- 3,051
MeJennifer said:Any topological model that fully describes SR and GR must actually remove the Hausdorff constraint. The problem is that Riemannian geometry requires a manifold to be Hausdorff, a fact, by the way, that was unknown at the time SR and GR was developed.
Why? Are you claiming that Riemannian requires [and not merely chooses for convenience] the Hausdorff condition? Can you provide a reference?
Historically, lots of things were unknown at the time SR and GR were being developed. For a long time, the emphasis was on systems-of-PDEs in coordinate patches and not the global structure underlying the modern formulations of spacetime [including causal structures].
MeJennifer said:One of the requirements for a metric on a Riemannian manifold is that it the triangle inequality must hold. The Minkowski "metric" which has a negative definite signature is obviously not a metric by that definition.
The triangle-inequality has some nice properties... which is needed for certain properties of Riemannian geometry. But, the clock effect tells us that that triangle-inequality is not satisfied by triangle with timelike-vectors... we have instead the reverse-triangle inequality.
FYI, Minkowski is NOT http://mathworld.wolfram.com/NegativeDefiniteMatrix.html" . It has signature (-+++) or (+---), depending on your convention.
In any case, as Riemannian generalizes Euclidean, Lorentzian (or more generally semi-riemannian) generalizes Riemannian. One can further generalize to Finslerian manifolds, complex-manifolds, non-metric manifolds, non-manifold topological spaces, etc... In the mathematical hierarchy, is there is anything so sacred about Riemannian geometry with its positive-definite metric?
The point for modeling the physical world is: which best models spacetime... [with hopefully each mathematical structure in model having some physical interpretation]?
(By the way, from a projective-geometric viewpoint [in the spirit of Felix Klein], one can see that Minkowskian geometry is a completely consistent geometric theory [as one does with Elliptic and Hyperbolic geometries].)
MeJennifer said:Now we could simply put the term "pseudo" in front of anything and be done with it but that does not make the real mathematical issue go away. It is a pseudo solution.![]()
This sounds like the comments that regard the complex numbers as "strange" number systems.
MeJennifer said:There is another way around it, by defining an "Einstein algebra", but then we cannot any longer think in terms of a topological model of space-time.
Geroch's Einstein Algebra? Using that does NOT say that you "cannot any longer think in terms of a topological model of space-time"... rather, you don't have to think in that way. You can [and do] use the Einstein Algebra for ordinary spacetime. (By the way, some noncommutative-geometric approaches use a similar approach.)
MeJennifer said:So in short, this is not an SR or GR problem, it is a mathematics problem.
Nevertheless and obviously, mathematics can still supply a workable framework for SR and GR, but clearly not an mathematically complete one.
It may be a mathematics problem... but don't lose sight of the physicist's goal: find the best model for spacetime [sufficient for the problem under study].
