Should I delete all PPAs to fix failed updates on Ubuntu 18.04?
  • Thread starter Thread starter member 428835
    Linux Ubuntu
On Ubuntu 18.04, users may encounter the error "Failed to download repository information" when attempting software updates. This issue typically arises from the inclusion of PPAs (Personal Package Archives) that do not have a Release file, indicating they are not maintained for the current version of Ubuntu. Specifically, repositories such as texstudio, gstffmpeg-keep, and equalx are not supported for Ubuntu 18.04 (Bionic), as they only cater to older versions like 12.04 and 14.04. To resolve the issue, users should consider removing these unsupported PPAs from the Software Updates settings. If a newer version of a package is needed, it is advisable to look for actively maintained PPAs or to upgrade the system to a more recent version of Ubuntu, such as 20.04, which offers extended support and more up-to-date packages.
member 428835
Hi PF
On Ubuntu 18.04 when I try and run software updates I get the error "Failed to download repository information". When I run apt-get in terminal I get
Code:
E: The repository 'http://ppa.launchpad.net/blahota/texstudio/ubuntu bionic Release' does not have a Release file.
N: Updating from such a repository can't be done securely, and is therefore disabled by default.
N: See apt-secure(8) manpage for repository creation and user configuration details.
E: The repository 'http://ppa.launchpad.net/mc3man/gstffmpeg-keep/ubuntu bionic Release' does not have a Release file.
E: The repository 'http://ppa.launchpad.net/q-quark/equalx/ubuntu bionic Release' does not have a Release file.
Any ideas? I'm thinking its a PPA issue. In Software Updates under Other Software should I delete all http://ppa.launchpad packages?
Computer science news on Phys.org
Based on this answer, the PPA you've added does not support your version of Ubuntu.
Checking the first one (texstudio), it seems to be the case. Only Ubuntu versions 12.04, 14.04, 14.10, 15.04 are supported. (Click the 'Technical details about this PPA' link to see this info)
Given the error messages that's a fairly safe deduction :biggrin:
Either that, or if you need a newer version than what is in the bionic repo then seek out actively maintained PPAs: for instance for texstudio the one linked from https://www.texstudio.org/
Or if my guess that you have just upgraded from 16.04 (which reaches EOL this month) is correct, delete all the PPAs and upgrade on through to 20.04 for another 2 years of support (and more recent versions of packages, although focal is still on 2.12.22 for texmate so if you want v3 you will still need Sundermeyer's PPA).
Likes member 428835
Thread 'ChatGPT Examples, Good and Bad'
I've been experimenting with ChatGPT. Some results are good, some very very bad. I think examples can help expose the properties of this AI. Maybe you can post some of your favorite examples and tell us what they reveal about the properties of this AI. (I had problems with copy/paste of text and formatting, so I'm posting my examples as screen shots. That is a promising start. :smile: But then I provided values V=1, R1=1, R2=2, R3=3 and asked for the value of I. At first, it said...
