Is ln(-1) Equal to Zero?
  • Context: Undergrad
  • Thread starter Thread starter alba_ei
The discussion centers on the evaluation of ln(-1) and its implications in both real and complex number contexts. Participants clarify that ln(-1) is not defined in the realm of real numbers, as the logarithm function is undefined for negative inputs. However, when considering complex numbers, ln(-1) can be expressed as iπ, based on the relationship e^(iπ) = -1. The discussion emphasizes the distinction between the natural logarithm for real numbers and its extension to complex numbers, where the identity a*ln(z) = ln(z^a) does not hold.
  • Understanding of logarithmic functions and their properties
  • Familiarity with complex numbers and their representation
  • Knowledge of Euler's formula, e^(iθ) = cos(θ) + i*sin(θ)
  • Basic concepts of complex analysis, including the argument and modulus of complex numbers
  • Study the properties of logarithms in complex analysis, focusing on the principal branch of the logarithm
  • Learn about the implications of Euler's formula in complex number calculations
  • Explore the differences between real and complex logarithmic functions
  • Investigate the generalization of logarithmic identities for complex numbers
Mathematicians, physics students, and anyone interested in advanced calculus or complex analysis will benefit from this discussion, particularly those exploring the properties of logarithmic functions in different number systems.
alba_ei
ln(-1) = 0 ?!
supposed that we have
\ln(-1)
then
\frac{2}{2}\ln(-1)
so
\frac{1}{2}\ln(-1)^2
this is equal to
\frac{1}{2}\ln(1)
and if this is equal to 0 the we can say that
ln(-1) = 0
is this right , wrong, are there any explanations for this?
The rule of logarithms is a lnx=lnxa. In this case, a=1-- you cannot split it into a fraction and then only take the numerator!
If you look at the logarithm graph, you will see that the function is not defined for negative x.
It's wrong. ln(-1) is no longer a real number, so you can't treat it like one. This is like saying sqrt(-1) = (-1)1/2 = (-1)2/4 = ((-1)2)1/4 = 11/4 = 1.
Actually, that step is perfectly valid in general - (a/a) ln(x) = 1/a ln(x^a), i.e. when everything is defined. Your next line explains why it's not valid here:
Course it is; sorry!
Really? Why can't one say that ln(-1)= i pi, for e^(i pi) = -1.
Or is there something wrong with that line of logic?
logarithm is defined also for complex numbers.
ln(z)=ln(abs(z))+i*arg(z), where z is complex number, abs(z) is complex norm of complex number z, and arg(z) is its argument.
So if -1 is treated as complex number -1+0*i, expression ln(-1) gives sense, but the identity a*ln(z)=ln(z^a) is no longer true.
To satisfy the pedants, I shall re-phrase my above answer. The natural logarithm function, whose argument is a real number and to whom we can apply the standard laws of logarithms, is not defined for negative real numbers.
for complex z: Ln(z) = ln(|z|) + i*Arg(z)
so ln(-1) = ln(|-1|) + i*Arg(-1) = i*pi
JonF said:
for complex z: Ln(z) = |z| + i*Arg(z)
so ln(-1) = |-1| + i*Arg(-1) = 1 + i*pi
Really? If you were attempting to define the principal branch of Ln, then it ought to be Ln(z) = ln(|z|) + iArg(z), where ln is just the natural logarithm on the reals.
In this case, we have Ln(-1) = ln(|-1|) + iArg(z) = i*pi.
eh forgot the ln, fixed
Cristo said, "for negative x". Since the complex numbers are not an ordered field, there are no "negative" complex numbers. Cristo was clearly talking about real numbers.
\log_e -1 = i\pi + 2ki\pi, k\in \mathbb{Z} Case Closed.
is the logarithm of complex numbers defined for any other base except 'e'?
Yes, you can still change between various different bases for your logarithms in the same manner as you do for Real numbers.
  • · Replies 29 ·
