Mentor
- 51,077
- 27,103
WannabeNewton said:Ok but if zero angular momentum is defined by the ZAMOs and angular momentum is measured relative to them, then what do we mean by angular momentum "about the black hole" relative to infinity?
Angular momentum isn't "defined" by the ZAMOs; it's defined as a parameter of the motion for a test object. A test object with 4-momentum ##p^a## has angular momentum ##L = g_{ab} \psi^a p^b##, where ##\psi^a## is the axial KVF (same notation as you were using). It happens that ZAMOs are the particular observers for which that formula for ##L## gives zero, but that doesn't mean angular momentum is "defined" by the ZAMOs; it's defined by the properties of the spacetime (and the 4-momentum of the observer, of course).
The term "relative to infinity" might not be a very good one, particularly with respect to angular momentum, since its behavior here doesn't match our intuitions (an observer with zero angular velocity has nonzero angular momentum, and vice versa). I don't know that there is any simple measurement that observers at infinity can make that gives an object's angular momentum, as there is for angular velocity (see below). My intent was simply to say something like the above.
WannabeNewton said:And similarly if the hovering observers define zero angular velocity and angular velocity should be measured relative to them, then what do we mean by angular velocity "about the black hole" relative to infinity?
Again, the hovering observers don't define zero angular velocity; the timelike KVF does, since it defines what it means to be "at rest" spatially. The hovering observers are just the ones who are following orbits of the timelike KVF. Here the term "relative to infinity" makes more sense since an observer at infinity can actually time the motion of objects and measure their angular velocity directly.
(The only complication here is that, of course, the result observers at infinity get will be different, because of gravitational time dilation, than the result an observer at finite radius with nonzero angular velocity, such as a ZAMO, will get when he times the passages directly overhead of some object at infinity. But that's easy to take into account if you need to.)
