Can a Lock-in Amplifier Handle -30dB SNR?
The discussion centers on the performance of a lock-in amplifier when subjected to a signal-to-noise ratio (SNR) of -30dB, which causes the device to fail in detecting the desired signal due to excessive noise. Despite specifications indicating that lock-in amplifiers can handle noise levels down to -100dB, the user struggles to understand this discrepancy, as their simulation shows the signal is obscured by noise. Participants suggest that averaging over many samples can improve SNR and that a lock-in amplifier can expedite measurements, although it may not be necessary for recovering signals from white noise. The user has not yet incorporated an analog-to-digital converter (ADC) or quantization in their simulation, which could further affect results. Overall, the conversation highlights the complexities of using lock-in amplifiers in noisy environments and the importance of averaging in signal recovery.
SvetaP
Hi,
I wrote a simulation of lock in amplifier using Matlab and now i want to test it for different SNR.
I added to the signal white gaussian noise. In all the spec that i read, always written that the lock in amplifier can handle -100dB of noise.
When I add a noise of SNR=-30dB the lock in stops working, when i look at the spectrum of the signal+noise i see that the component that i am looking for is covered by noise so no wonder that the lock in doesn't work.
what i don't understand how is that in spec always written that lock in works at -100dB? i think that i am missing something.
attached spec of lock in amplifier : http://infrared.als.lbl.gov/content/PDF/equipment/SR810830_specs.pdf
look at the part of dynamic reserve.
I didn't add any ADC and quantization yet. So the system only consist of sinus signal that is the signal and reference and Gaussian noise.
Thanks for any help.
If you have truly white noise you can recover any signal if you average for long enough (the SNR improves as the square root of the number of samples).. Hence, you do not even need a lock-in amplifier (although using one will make the measurement much faster).
What is the time-constant of your simulated lock-in?
You should also be able to see the peak corresponding to your signal by just averaging over many simulated spectra.
Instead of using LPF in the end of lock in , i used averaging as perfect LPF.
explanation of simulation and results attached.
Thread 'I thought it was only Amazon that sold unsafe junk'
I grabbed an under cabinet LED light today at a big box store. Nothing special. 18 inches in length and made to plug several lights together. Here is a pic of the power cord: The drawing on the box led me to believe that it would accept a standard IEC cord which surprised me. But it's a variation of it. I didn't try it, but I would assume you could plug a standard IEC cord into this and have a double male cord AKA suicide cord. And to boot, it's likely going to reverse the hot and...
11K
55K
