Logically Prove (A \cup B) \subseteq C
  • Thread starter Thread starter ajsingh
    Proof
2 replies · 3K views
ajsingh
To prove [tex]A \subseteq C and B \subseteq C[/tex] implies [tex](A \cup B)\subseteq C[/tex]
2. The attempt at a solution
I just wanted to know if my reasoning seems logical. Here is my attempt:
Assume [tex]A \subseteq C and B \subseteq C ... (1)[/tex]
Assume [tex]\forall x [ x\in A] and \forall x [x \in B] ... (2)[/tex]
Hence, from definition of [tex]\bigcup \forall x [x \in A \cup B ] ... (3)[/tex]
From (1) and defination of [tex]\subseteq, \forall x [ x \in A \Rightarrow x \in C and x \in B \Rightarrow x \in C ] ..... (4)[/tex]
Hence, [tex]\forall x [x \in A \cup B \Rightarrow x \in C] ..... (5)[/tex]
[tex]\Rightarrow (A \cup B) \subseteq C<br /> [/tex]
Does that seem to flow logically?
Thanks
Hi Ajsingh!
I think your progression is correct except for premise 2. You say that x is an element of A, AND, x is an element of B. That can be true, but it doesn't have to be true. I recommend switching the AND to an OR. After you make that change, I don't see any fault in your logic. I also think it flows better if you switch premises 3 and 4. I know it's semantics but the progression seems better to me.
I also want to point out that unless specified in the problem, it might be enough to simply demonstrate that this proof is true. What if you assigned C={1,2,3,4,5}, A={1,2,3}, B={3,4}
A is a subset of C. B is a subset of C, A U B = {1,2,3,4} which also is a subset of C. Proved. I mention this, because it also shows a contradiction to your premise #2. Namely, 4 is an element of B but NOT an element of A.
Hope this helps!
Steve
You want to prove one set is a subset of another. The standard way of doing that is to say "if x in the first set" and show "therefore x is in the second set".
While this isn't, strictly speaking, wrong, you don't need to "assume" that- it is given.
Now you don't want to say that! For one thing, A and B might be disjoint- there might be no such x! What you want to say is "Assume [itex]x\in A\cup B[/itex].
x doesn't have to be in both A and B in order to be in [itex]A\cup B[/itex]!
[quote\From (1) and defination of [tex]\subseteq, \forall x [ x \in A \Rightarrow x \in C and x \in B \Rightarrow x \in C ] ..... (4)[/tex]
You are going the wrong way. Starting from the assumption that [itex]a\in A \cup B[/itex] it follows that either [itex]x\in A[/itex] or [itex]x\in B[/itex].
Thanks
