What is the role of the longitudinal rapidity in relativistic contexts?
  • Context: Undergrad
  • Thread starter Thread starter SiennaTheGr8
The discussion centers on the concept of longitudinal rapidity, defined as ##\varphi = \tanh^{-1} \beta_x##, which is crucial in relativistic contexts. Unlike the standard rapidity vector, longitudinal rapidity takes the sign of the velocity component along the boost axis, allowing for additive transformations under boosts. This property ensures that changes in longitudinal rapidity are invariant, making it a more flexible parameter for analysis in particle physics. The discussion emphasizes the importance of recognizing longitudinal rapidity for accurate relativistic calculations.
  • Understanding of special relativity concepts, including rapidity and velocity components.
  • Familiarity with hyperbolic functions and their inverses, particularly ##\tanh## and ##\tanh^{-1}##.
  • Knowledge of Lorentz transformations and their application in relativistic physics.
  • Basic grasp of particle physics terminology and concepts, such as three-force and celerity.
  • Study the properties of hyperbolic functions in the context of special relativity.
  • Learn about Lorentz transformations and their implications for velocity and rapidity.
  • Explore the applications of longitudinal rapidity in particle collision scenarios.
  • Investigate the relationship between rapidity and invariant mass in relativistic systems.
Physicists, particularly those specializing in particle physics and relativistic mechanics, as well as students and researchers looking to deepen their understanding of rapidity and its applications in high-energy physics.
SiennaTheGr8
In relativity contexts, "rapidity" is usually defined as ##\phi = \tanh^{-1} \beta##, always positive like ##\beta##. One sometimes also encounters the rapidity vector, ##\vec \phi = \phi \hat \phi = \phi \hat \beta##, with Cartesian components like ##\phi_x = \phi \cos{\theta} = \tanh^{-1} (\beta) \cos{\theta} ## (where ##\theta## is the angle between ##\vec \phi## and the positive ##x##-direction).
That's all well and good, but I'd argue it's of limited use. For more flexibility, we want a signed rapidity-like parameter, and the components of the rapidity vector don't quite fit the bill (explained below).
The quantity we're looking for is what particle physicists (unfortunately) call "rapidity." To avoid confusion, I'll call it longitudinal rapidity and label it ##\varphi## (curly phi). I want to make the case that this longitudinal rapidity deserves more recognition in relativistic contexts.
The longitudinal rapidity is defined as the inverse hyperbolic tangent of the Cartesian velocity-component parallel to a given boost axis (normalized velocity, I should say). So if the boost is along the ##x##-axis, the longitudinal rapidity is ##\varphi = \tanh^{-1} \beta_x = \tanh^{-1} (\beta \cos \theta)##, where ##\theta## has the same meaning it had a few paragraphs up. Naturally ##\varphi## takes the sign of ##\beta_x## (hyperbolic tangent and its inverse are odd functions).
We see that in general, ##\varphi \neq \phi_x##. The exception is when ##\phi_x## is the only non-zero component of ##\vec \phi## (motion in the ##\pm \, x##-direction).
What's nice about the longitudinal rapidity (as opposed to ##\phi_x##) is that it transforms additively under the boost in question, and—consequently—that changes/differences in it are invariant under the boost. The additivity of the transformation follows simply from the transformation rule for ##\beta_x## under a boost along the ##x##-axis:
##\beta^\prime_x = \dfrac{\beta_x - \beta_{\textrm{boost}}}{1 - \beta_x \, \beta_{\textrm{boost}}}##
##\tanh \varphi^\prime = \dfrac{\tanh \varphi - \tanh \phi_{\textrm{boost}}}{1 - \tanh \varphi \, \tanh \phi_{\textrm{boost}}} = \tanh (\varphi - \phi_{\textrm{boost}})##,
so that ##\varphi^\prime = \varphi - \phi_{\textrm{boost}}##. The invariance of changes/differences in longitudinal rapidity under said boost then follows by transforming ##\varphi_2 - \varphi_1##:
##\varphi^\prime_2 - \varphi^\prime_1 = (\varphi_2 - \phi_{\textrm{boost}}) - (\varphi_1 - \phi_{\textrm{boost}}) = \varphi_2 - \varphi_1##.Here is a neat application, an elegant demonstration that the Cartesian component of three-force ##\vec f## that's parallel to an object's three-velocity ##\vec \beta## is invariant under a boost in the ##\pm \, \hat \beta## direction (for constant ##m##). An overdot is a ##ct##-derivative (coordinate time), and an over-circle is a ##c \tau##-derivative (proper time). The celerity is ##\vec \omega = \gamma \vec \beta##.
##\vec f = \dot{\vec p} c = (mc^2) \, \dot{\vec \omega}##
##f_x = (mc^2) \, \dot{\omega}_x = \dfrac{(mc^2) \, \mathring{\omega}_x}{\gamma} ##.
With the ##x##-axis as boost axis, the longitudinal rapidity is ##\varphi = \tanh^{-1} \beta_x##, and so the ##x##-component of the celerity is ##\omega_x = \gamma \beta_x = \cosh \phi \, \tanh \varphi##. Now impose the condition that the three-velocity is in the ##\pm \, x##-direction. In this special case (as we covered above), ##\varphi = \phi_x = \pm \, \phi##, and that gives ##\cosh \varphi = \cosh \phi = \gamma## (even function). So ##\omega_x = \cosh \varphi \, \tanh \varphi = \sinh \varphi##:
##f_x = \dfrac{mc^2}{\cosh \varphi} \, \dfrac{d}{d (c \tau)} \sinh \varphi = (mc^2) \, \mathring{\varphi}##.
Can you provide some references for the rapidity vector?
  • · Replies 36 ·
  • · Replies 175 ·
26K
  • · Replies 17 ·
320K
