Calculating Minimum Water Level in a Barrel using ODE: Analysis and Approach
  • Thread starter Thread starter Mathman2013
    Bound Ode
The differential equation dV/dt = 5 - 2 * V(t)^(1/3) models the draining of a barrel initially containing 25 liters of water. Setting dV/dt to zero yields a minimum water level of approximately 15.625 liters, indicating that this is the lowest volume the barrel can reach during drainage. The initial condition of 25 liters is crucial for determining the time it takes to reach this minimum, as the volume decreases over time. The discussion confirms that the approach to finding the minimum is correct, and no alternative methods are necessary. Understanding the relationship between V and time is essential for a complete analysis of the problem.
Mathman2013
Find the lower bound of the ODE?
dV/dt = 5 - 2*V(t)^(1/3)
I have following differential equation dV/dt = 5 - 2 * V(t)^(1/3) which represents a the time its take to drain a barrel of rain water which contain 25 Liter of water, at t = 0.
I am suppose to calculate the least amount of water in barrel during this process.
If I set the rate of growth to zero, meaning dV/dt = 0, then 5 - 2 * V^(1/3) = 0, and thusly V = (5/2)^(3) = 15.65, meaning the least amount of water which is in the barrel is 15.65 L,if the rate of change is zero.
But question, is this correct why at handling this problem? Because I am not really using the info, that t = 0, the barrel contains 25 L.
Any idea? On how to approach this problem differently?
Mathman2013 said:
Homework Statement:: Find the lower bound of the ODE?
Relevant Equations:: dV/dt = 5 - 2*V(t)^(1/3)
You're off by a little bit -- I get the least amount as 15.625 L (125/8 == 15.625).
Yes, this is the right approach. Since water is draining from the barrel, dV/dt will be negative, so at a time when dV/dt = 0, the volume will be at a minimum.
One interpretation for this scenario is that the barrel has a hole in it somewhere above the middle of the barrel.
No need for a different approach.
V is strictly increasing if and only if V(t) < 125/8\,\mathrm{L} and strictly decreasing if and only if V(t) > 125/8\,\mathrm{L}. Which of those regimes does V(0) = 25\,\mathrm{L} fall into?
You would need that information if you wanted to determine how long it takes for the volume to reach the minimum. That would obviously depend on how much you start with.
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
  • · Replies 18 ·
  • · Replies 27 ·
