MATLAB Ltiview and negative step response of a linear system
The discussion revolves around a code issue related to evaluating the response of a linear system to a negative step input. The original code provided by the professor successfully generates a response for a positive step using the lti view function in MATLAB. However, the user seeks guidance on how to modify the code to visualize the system's response to a negative step input. Suggestions include consulting the MathWorks documentation for relevant functions and parameters, and checking with the professor for further clarification. A key point mentioned is that for linear systems, the response to a negative step is simply the negation of the response to an equivalent positive step, which can simplify the analysis. The user ultimately found a solution using Simulink.
dRic2
Hi, my professor gave me I code where he used to evaluate the answer of a linear system to a step increase in the input variables like this:
Code:
MySystem = ss(A, B, C, D);
ltiveiw('step', MySystem, 'r-', 300);
My problem is that with this code I get the response only for a positive step. I'd like to see what happens for a negative step as well, but I can't figure out how to do it.
Thanks
Ric
Check the MathWorks site on these functions you might spot something to help you there.
I did find this reference creating a state space that is input to the lti view function
https://www.mathworks.com/help/control/ref/ss.html
This may be where you can define your params.
If not check with your prof if possible.
Thanks, I'll keep searching.
(ended up using SimuLink)
If the system is linear, the response to a negative step is the negation of the response to a positive step of the same size.
Likes dRic2
