Magnetisation Curve (Synchronous Machines)
  • Thread starter Thread starter buildingblocs
    Curve Machines
The discussion focuses on the magnetization curve of synchronous machines, specifically the relationship between open circuit voltage (V[oc]) and closed circuit current (I[sc]) versus excitation current (I[x]). It highlights that saturation is observed in the V[oc] versus I[x] curve, while the I[sc] versus I[x] curve remains linear. This difference is attributed to the conditions under which the tests are performed, with saturation effects visible in the open-circuit test at zero stator current, while the short-circuit test shows low internal voltage, preventing saturation observation. The relationship between voltage and magnetic flux is emphasized, indicating that higher voltage requires higher flux, which leads to increased saturation. Understanding these dynamics is crucial for analyzing synchronous machine performance.
buildingblocs
Hi All,
Today I conducted a lab in which we plotted the open circuit voltage (V[oc]) and closed circuit current (I[sc]) versus the excitation current in the rotor (I[x]).
From the data (plots are attached to thread), it can be seen that saturation occurs in the V[oc] versus I[x] curve however the I[sc] versus I[x] curve remains linear.
Why is it that saturation occurs only with V[oc] and not with I[oc] in the stator?
Open-circuit curve (stator voltage vs excitation current) test is performed (or calculated) at zero stator current and 0-1,2 of rated stator voltage. In this case saturation of magnetic circuit is clearly visible.
Short-circuit curve (stator current vs excitation current) test is performed at shorted stator terminals 0-1.0 of rated stator current. Stator voltage (internal stator voltage) is quite low during the test, so you won't observe effects of saturation.
So why saturation is dependent on voltage ? Remember that equation: E=4,44*f*ψ*z
where: E-voltage (stator), f-freuqency, ψ-magnetic flux, z-number of turns
Frequency is static, numer of turs also. Only voltage and flux chanches, so: E≈ψ
The higher voltage, the higher flux is required. Higher flux means higer saturation.
Likes 1 person
I am trying to understand how transferring electric from the powerplant to my house is more effective using high voltage. The suggested explanation that the current is equal to the power supply divided by the voltage, and hence higher voltage leads to lower current and as a result to a lower power loss on the conductives is very confusing me. I know that the current is determined by the voltage and the resistance, and not by a power capability - which defines a limit to the allowable...
34K
  • · Replies 22 ·
