Majorana mass term for the electron
16 replies · 4K views · last reply
zaman786
TL;DR
violation of charge conservation of Majorana mass term
hi, while studying Majorana mass term can be added for the neutrino - as they are neutral - but cannot be added for the electron -as it would violate the charge conservation - i could not understand how charge conservation for Majorana mass term of electron is violated.
kindly help
Please write down the Majorana mass term, and identify its elements - e.g. this is a left-handed electron field.
Alternatively, just check how such a term would behave under a U(1)_EM transformation. You should find it is not invariant
and left handed electron field comes in doublet
Well, it does, but you still haven't written down what I asked.
Majorana=1/2mψˉcψ
zaman786 said:
Majorana=1/2mψˉcψ
Well, after almost a week, we are almost halfway there.
Further, what you wrote down is NOT what the images shows.
If you're not willing to put in any work, why should I?
Enough is enough. I keep asking you to please write down the Majorana mass term, and identify its elements - e.g. this is a left-handed electron field. and you keep not doing it.
Maybe someone else will help you. I am concluding this is a waste of time. If it's not worth your time to write down the next step of the problem. it can't be worth my time to help you with the step after that.
I think they believe they have done what you ask. It would seem to be a problem of ability rather than refusal. But maybe that’s just my reading.
The really simple thing to do though is to look at the terms here:
zaman786 said:
sorry , for delay
and do a U(1)_EM transformation. Since the electron is charged under EM, this will mean ##\psi_{eL} \to e^{i\phi} \psi_{eL}## for some ##\phi##. Then the OP should be able to answer the question ”is the Majorana mass term invariant?”
I don't think you understand what any of the terms mean - that's why you can't answer my hint.question, and that's why you still have questions after a perfectly good answer has been posted twice. You need to back up a few chapters and learn what the terms you are writing down mean.
You might also want to tale the time to learn to post equations here. PDFs of scribblings are not helpful/
th
thanks for your guidance- i have books on particle - but i will appreciate if you recommend some -
