Making a piecewise function continuous everywhere
5 replies · 2K views
ninty45
Given the piecewise function
[itex] f(x) = \left\{<br /> \begin{array}{lr}<br /> \frac{(2-x)^2-p}{x} &: x < q\\<br /> r(x+6) &: q \leq x <2 \\<br /> x^3-p &: x \geq 2<br /> \end{array}<br /> \right.[/itex]
Find the values of p,q,r such that f(x) is continuous everywhere and f(2) = p
Since f(2) = p,
[itex] f(2) = (2)^3 - p = p\\<br /> 8-p=p\\<br /> p=4[/itex]
If f(x) is continuous everywhere, then
[itex] \lim_{x \to 2} f(x) = f(2)[/itex]
But f(2)=p, and r(x+6) is always smooth, hence
[itex] r(2+6) = 4 \\<br /> r = \frac{1}{4}[/itex]
My difficulty is with q. Again from (assumed) continuity, at x=q,
[itex] \lim_{x \to q} f(x) = f(q) \\<br /> \lim_{x \to q} \frac{(2-x)^2-4}{x} = \frac{1}{2}(q+6) \\<br /> \lim_{x \to q} x-4 = \frac{1}{2}(q+6) \\<br /> 2q-8 = q+6 \\<br /> q=14[/itex]
but from the original function, q <2. The answer given is supposedly q=0, but I do not see then how the function could be continuous.
Are my calculations wrong? I tried assuming that q =0, hence instead of factorising the limit I used l'hopital but no dice.
I am including the original picture as a comparison.
There's a bit of a error there, I'm sorry to say.
My mistake. I wrote that incorrectly, it should be [itex]r=\frac{1}{2}[/itex].
However in the following working, I indeed used [itex]r=\frac{1}{2}[/itex].
You are correct. In order that f(2)= 2, p must be 4 and in order that the function be continuous at x= 2, r must be 1/2 (you say "1/4" but I presume that is a typo since you later use "1/2"). But in that case, there is NO value of q, less than 2, such that [itex][(2- q)^2- 4]/q[/itex] is equal to (1/2)(q+ 6) so there is no value of q, less than 2, such that f(x) is continuous at x= q.
The question looks wrong. Also, it doesn't cover the case where x = 0, so I assume there is a typo somewhere.
Thanks for the replies. I'll just chalk this one up as one of those incorrect questions.
