Manipulating Equations for Perpendicular Oscillations
8 replies · 3K views
Xsnac
I have 2 perpendicular oscilations and I have to find the trajectory equation.
$$x=A\cos\omega t\,\,\,\,\,\,\,\,\,\,\,\,\,\,\,\,\,\,\,\, (1)$$
$$y=B\cos(\omega t+\Delta\phi)$$
$$\cos (x+y) =\cos x\cos y -\sin x\sin y$$
$$\cos^{2} x+\sin^{2} x =1$$
and from (1)
$$\cos\omega t =\frac {x}{A}$$
I basicaly spent 2 hours trying to algebraicaly manipulate the equationThe closes I could get was:
$$\frac {y^{2}} {B^{2}} -2\frac {xy} {AB}\cos\Delta\phi + \frac {x^{2}} {A^{2}}\cos^{2}\Delta\phi = (1 - \frac{x^{2}} {A^{2}} )sin^{2}\Delta\phi\,\,\,\,\,\,\,\,\,\,\,\,\,\,\,\,\,\,\,\, (2)$$
The end result should be:
$$\frac {x^{2}} {A^{2}} +\frac {y^{2}} {B^{2}}-2\frac {xy} {AB}\cos\Delta\phi=sin^{2}\Delta\phi \,\,\,\,\,\,\,\,\,\,\,\,\,\,\,\,\,\,\,\, (3)$$
I have no ideea how to get from (2) to (3). :mad:
Thank you in advance for reading this wall of text.
I'm not sure what you want. You already have parametric trahectory equations: x(t) = stuff; y(t) = other stuff
Do you want a coordinate equation y(x)?
I don't know how to get from (2) to (3). I want to know the steps I have to make to get from (2) to (3)...
$$\cos x+y =\cos x\cos y -\sin x\sin y$$
and from (1)
We need to see the details: what are the steps you took to get to your (2)? Perhaps you made some errors, but we cannot tell until you show us.
For the record: I get the result (3).
BTW: your equation ##\cos x+y =\cos x\cos y -\sin x\sin y## is almost certainly false, as it says ## y + \cos x =\cos x\cos y -\sin x\sin y##, which is untrue for most ##x,y##. However, an equation such as ##\cos (x+y) =\cos x \cos y -\sin x \sin y## is true for all real ##x,y##.
sorry it was a typo ... well the stepps I took are the following
I expanded the cos function of $$y=B\cos(\omega t+\Delta\phi)$$
and replaced all the $$\cos\omega t$$ with $$\frac {x}{A}$$
then I transformed the $$\sin\omega t$$ into $$\sqrt{1 - \frac{x^{2}} {A^{2}}}$$
In the end I divided everything by B and squared everything to get rid of the root.
Transforming ##\sin(\omega t)## into ##\sqrt{1 - \cos^2(\omega t)}## is a mistake, as it eliminates the parts where ##\sin(\omega t) < 0##. The point is that, by definition, ##\sqrt{ \cdot } \geq 0## for any real argument, but sometimes you want to have ##\sin(\omega t) = - \sqrt{1 - \cos^2(\omega t)}##. It is a lot easier to just use ##u = \cos(\omega t), v = \sin(\omega t)## and then express ##x(t), y(t)## in terms of ##u,v##. Of course, ##u^2 + v^2 = 1## for all ##t##.
Ur wrong. I figured it out with a little help from someone else. Had to multiply the right parenthesis with $$\sin^{2} \Delta \phi$$ , move the second term to the left side, factorise out $$ \frac {x^{2}} {A ^{2}} $$ and then the remaining equation is identical to (3)
reminder of what I had
and where I got
and where I got
No, I am NOT WRONG. Writing ##\sin(r) = \sqrt{1 - \cos^2(r)}## can be incorrect, and by definition of the function ##\sqrt{ \cdot }##, it is ##\geq 0## for all real arguments. Those are just plain facts.
These issues have been explained over and over again, many times, in numerous discussions in this forum. I did not make these things up.
Aside from that, whether of not expressing ##x,y## in terms of ##u,v## and then using ##1 = u^2 + v^2## is easier or harder than some other way is largely a matter of opinion; I found it easier.
Ur wrong in the sense that saying what you just said is not getting me closer to solving the problem. But thank you anyway.
