Mass in rotating circular tube and spring extension problems
5 replies · 4K views · last reply
orange_angel
Two Physics Problems .. plsss help ??!
Q1 :
The figure shows a mass M inside a tube bent in a circle of radius R=1.20 m. M can slide with negligible friction inside the tube. The tube rotates about a vertical axis passing through the center. The mass is in equilibrium at q =56.5 degrees. Calculate the number of revolution the hoop makes in 12.0 s.
THE FIGURE : http://www3.0zz0.com/2006/12/22/10/35335598.gif
Q2:
A 8.40 kg mass suspended from a spring with spring constant, k = 800.0 N/m, extends it to a total length of 0.270 m. Find the total length of the spring when a 13.40 kg mass is suspended from it.
orange_angel said:
Q1 :
Q2:
You will have to show what you have done to attempt a solution.
AM
the second question :i don't know how to begin !
the first question
F=kx, where F is the force applied, k is the spring constant and x is the distance stretched.
k = 800 N/m
x=0.270
F=kx=800*0.270=216N/m
I don't know how to find the total length of the spring ..
[ i never learn physics before .. i have many problems ! I'm trying to be better ..]
orange_angel said:
k = 800 N/m
x=0.270
Careful: 0.270 m is the total length of the spring, not the amount of stretch. Use Hooke's law to figure out how much the spring stretched when the weight was added--this will allow you to calculate the unstretched length.
Hint for question #1: What kind of motion does the mass undergo? What kind of acceleration?
ok ..
in question 2 :
maybe i have to do that :
F=mg=13.40*9.81=131.454 N
x=F/k=131.454/800=0.1643m
is it right ??
That's certainly an essential step in solving the problem. What is the meaning of what you have calculated, and how does it relate to the final solution?
