Mass of a helical wire turn with exponential linear density
2 replies · 2K views
krtica
Find the mass of one turn of wire in the form of a helix with a linear density e^(-z) in lbs/ft.
Would I write as <e^(-z)*cost,e^(-z)*sint, t>? Maybe?
The first thing to check for is units. The problem with your proposed solution is that the x and y components have units of weight, while the z component has units of length.
What is given is the density (ratio weight per length), so to get weight just multiply the density by the length. The arclength of a curve is given as the integral of the modulus of the derivative of the curve. So just put the density inside the integral and solve.
krtica said:
Find the mass of one turn of wire in the form of a helix with a linear density e^(-z) in lbs/ft.Would I write as <e^(-z)*cost,e^(-z)*sint, t>? Maybe?
First, you should note that the problem is not well posed. It makes a difference which turn of the wire since the density is not constant. You want to calculate
[tex]\int_C \delta(x,y,z)\ ds[/tex]
with appropriate units.
