Mass of a paper clip question
  • Thread starter Thread starter zelda1850
    Mass Paper
The discussion revolves around estimating the mass of a paper clip, presented as a multiple-choice question with various exponentials in kilograms. Participants explore the context of scientific notation and the concept of mass in everyday terms.
  • Some participants question the validity of the answer choices, suggesting that three options seem unreasonable. Others propose using common items for comparison, such as a penny or a package of food, to gauge the mass of a paper clip.
The conversation includes various perspectives on estimating mass and understanding scientific notation. Participants have offered insights into how to approach the problem conceptually rather than through calculation alone, emphasizing the importance of common sense and familiarity with mass units.
There is an emphasis on understanding the concept of a kilogram and how it relates to everyday objects. Some participants note that the problem is designed to encourage reasoning rather than simply calculating a weight.
zelda1850
the mass of a paper clip is approximately?
it is mutiple choice but i don't know if there an equation for it
the mass of a paper clip is apporoximately?
1) 1 x 10 exponenet(6) kg
2) 1 x 10 exponenet(3) kg
3) 1 x 10 exponenent(-3) kg
4) 1 x 10 exponenent(-6) kg
i have no idea how to do this problem ...
There is no formula. Three of the options are ridiculous.
The question is designed to see if you understand
a] exponents,
b] how to ballpark, and
(possibly most important)
c] how to understand a problem, rather than just being a calculating machine.
Steel weighs about 490#/cu.ft so estimate/calculate the volume of a paper clip and go from there.
Maybe you have played around with masses in a lab? Or you have passed around a 1 kg mass? A 100 gram mass (0.100 kg)? I think your teacher may have two or three things in mind.
1. Do you have some feel for what a kilogram is? Maybe like you have a feel for about how long a foot is or a meter. Or maybe you can estimate how much of a pound a pea weighs.
2. Do you understand scientific notation?
maybe try to think about it in terms of grams
it definitely has a negative exponent
i think this one is more of a common sense question...
If you must, try converting from kg to pounds or ounces, if you are more familiar with those units.
As a reference, find a package of food, any type of food, which lists the mass on the package. Is a paper clip heavier or lighter than this? That should help eliminate 2 of the answers.
Go to Staples or Office Max. Get a box of 100 paper clips. Weight it on a letter scale. Divide by 100.
Just for a ballpark estimate, is a paper clip lighter than a penny? What is the mass of a penny? If you know how to handle exponents, the answer should be evident quickly.
The point of this homework problem is not to weigh a paper clip, it is to use some common sense.
The problem can be common sense is not common when one has no idea what a kilogram is. We can be sure the poster is not a drug dealer, in the U.S. anyways. Which is a good thing.
The point is to get an idea what a kilogram is. If one doesn't know that, at least use the conversion to pounds. Going out and weighing to get the mass of a paper clip defeats the purpose.
Ok, well first approximate, do you know what a kg is equal to? about 4 apples, now consider a small paper clip, it is very small compared to those apples, a tenth? a thousandth? a millionth? well you are in luck because it is multiple choice, so it is most likely 1EE-3
If you don't know scientific notation (which you should, it will come up again) the -3 means the total number of digits. So 1EE-3 = .003th of a kg or 1g, 1g ~ a paper clip
Good estimation is a valuable tool in science and IRL, the important thing is not the detail (3 or 4EE but the exponent, EE3, and EE6 is a big difference, you should be able to pick a reasonable answer)
  • · Replies 21 ·
  • · Replies 16 ·
