Mass on an Incline with Spring Attached
36 replies · 8K views · last reply
whoareyou
Physics diagram of a block attached to a spring at the top of a frictionless ramp, with the ramp marked 3.00 m high and 4.00 m along its base and the block's distance along the incline labeled 3.00 m.
Forces and/or energy
I honestly don't know where to start. First I tried kx = mgsin(tan-1 (3/4))) and got the answer E, which is wrong. Then I tried using energy, mgh = 1/2kx^2 which resulted in an answer that wasn't on the list. Any ideas on how to begin?
Because total mechanical energy of the system is conserved?
Edit: nvm I figured it out!
Why is ##kx = mg \sin \theta## wrong here?, ##\theta## the inclination of ramp.
Well, it violates the law of conservation of energy.
If you slowly let the mass slip until it was stationary then you'd be right, but that is not what's happening here.
Perhaps I misinterpreted something: when the mass is released, it obeys ##mg\sin\theta - kx = ma_x##So if they were ever equal, then the block would then move at constant speed.
The energy approach would indeed seem more appropriate.
Indeed it is.
The point of where the mass momentarily stops moving is not the point of zero acceleration. It is the point of zero velocity.
Yes, but what does the acceleration vectors look like in such a case? It can't be like the vectors on a pendulum, so the acc. vectors will lie along direction of motion.
Let s = distance along ramp starting from the point where the spring is relaxed, where s = 0:
Then form F = ma:
-ks + mg sin(θ) = md2s/dt2
Solve this differential equation for s, take ds/dt and then d2s/dt2 gives you your acceleration. You will find s(t) and its derivatives are non-decaying oscillations.
You can also solve the given problem this way instead of invoking energy arguments: solve for ds/dt and set ds/dt = second zero (the first is obviously when you let go of the mass). Then solve for T, the time of the second zero of ds/dt, and then s(T).
how would you find ma_x?
You can't find it directly by other means, other than solving the differential equation, that is you set by definition ##a_x=\frac{d^2x}{dt^2}## and solve the differential equation $$mg\sin\theta-kx=m\frac{d^2x}{dt^2}$$.
However this problem can be solved by energy method without solving a differential equation, just an algebraic equation.
$$mgh=\frac{1}{2}kx^2$$
$$h=x\sin\theta$$
Since this is quite an old thread, i suppose i can give the answer, it is C. 0.235m
$$h=x\sin\theta$$
So for this one, would you use the same method? I'm somehow getting 0.1178 for 2b and 0.245 for 2a.
  • Question 2 text with a free-body diagram of a 10 kg block on a 30 degree incline, attached to a spring labelled k = 200 N/m anchored at the top of the slope.
I did it and i get 0.5m for a) and 0.24m for b). used g=10m/s^2. Please post your workings here if you want me to comment on them.
My friend did 2a and i did 2b. Both are far off. First image is 2a and second image is 2b
Handwritten free-body diagram of a block on a 30 degree incline attached to a spring, with forces labelled F_s, N, mg and an upward arrow along the slope, followed by the equation sum of Fx = 0 solved to give x = 0.245 m.
Handwritten working on lined paper: mg sin θ = kx + μmg cos θ, then 10(9.81)sin(30) = kx + 0.3(10)(9.81)cos(30), giving kx = 23.56, then kx = mgh giving h = 0.24 m, and kx = 23.56 giving x = 0.1178 m.
  • Handwritten working on ruled paper: mg sin θ = kx + μmg cos θ, then 10(9.81)(sin 30) = kx + 0.3(10)(9.81)cos 30, kx = 49.05 − 25.49, kx = 23.56, kx = mgh, h = 0.24 m, and x = 23.56/200 = 0.1178.
I thought we were going to do it by energy method but you are using force method and by doing so you are wrong. You calculate the position where the total force is zero, hence where the acceleration is zero. But we want the position where the velocity is zero.
Do you equal potential energy to kinetic energy?
nope. For a) i equal gravitational potential energy to elastic potential energy of the spring.
for b) i use work energy theorem $$W_{TOTAL}=\Delta K$$. We know that $$\Delta K=0-0$$ since the block starts from rest, and the end position is also one with zero speed. So calculate the total work and set it to zero. You ll have one equation with one unknown, the displacement of the spring x.
Better use work energy theorem for a) too . The logic is the same as for b), it is just that the total work is different in each case.
I'm a little confused :(. I don't know what W_total is.
It is the total work done on the block. Haven't you been introduced to the concept of work , and to work-energy theorem yet?
Also, did you use energy theorem for the original post?
I got 0.0589 on 2b when i do xsin30. My answer is /10 by the right answer and i also got 0.0235 instead of 0.235 as the answer to the original post
No i used conservation of energy actually for the OP, but it can be done with work-energy theorem as well, we ll get almost the same equations.
First of all tell me the answer key for a) and b) please.
Second what do you mean by "do xsin30".
And show me your working for the OP.
$$h=x\sin\theta$$
x represents the extension right?
Does Delta K represent the change in spring constant?
No ##\Delta K## is the change in kinetic energy of the block. I use the capital letter ##K## for kinetic energy. The one for the spring constant is the small letter ##k##.
