Mass-Spring Systems and the Relationship Between Force, Displacement, and Energy
The discussion revolves around a mass-spring system where a mass is subjected to a constant force, leading to a momentary stop after a displacement of 10 cm. The context includes concepts of force, displacement, kinetic energy, and elastic potential energy.
  • Participants explore the relationship between the applied force and the spring force, questioning the implications of the mass coming to a stop. There are inquiries about the kinetic energy during the process and its transformation into elastic potential energy.
The discussion includes attempts to clarify the original poster's reasoning and the implications of the mass's momentary stop. Some participants have offered insights into energy transformations, while others emphasize the need for complete information to provide accurate guidance.
There is a noted lack of complete information in the original problem statement, which has led to questions about additional details and the necessity of using a specific formatting template for clarity.
Raios168
A mass is attached to a spring which is mounted onto a wall. This mass is on a frictionless horizontal surface. You apply a CONSTANT force to the mass and it comes to a stop in 10 cm.
My question is, that since the mass comes to a stop in 10 cm then:
Force Applied = kx where x is 10/100 m
Is my reasoning correct? Thanks in advance
Hi Raios168. Please use the entire formatting template when you post a problem.
What happens to the kinetic energy that the mass gains while the spring force is less than the applied force?
Is that the only question in the problem statement given to you; or, are there additional questions to be answered?
This is not the entire question I just wanted to know if my thinking was correct. The entire question with the variables is as follows:
A mass (1.20 kg) is attached to a spring (k = 790 N/m) which is mounted onto a wall. This mass is on a frictionless horizontal surface. You apply a CONSTANT force to the mass while the spring is in the unstretched position and the mass comes to a momentary stop in 10 cm.
The kinetic energy becomes elastic potential energy doesn't it?
It's impossible for us to tell that with only the information you've given us. We could guess, and if we guess wrong we do more damage than good.
Which is why you need to fill out the template.
Without the template we cannot help you.
I think the key in the question is the "momentary stop". What provided the energy or (work) to get it to that point?
It does. And the KE built up while the spring's force is less than the applied force allows the mass to pass the point where the two forces are equal. That's why mass-spring systems oscillate.
  • · Replies 56 ·
  • · Replies 58 ·
  • · Replies 17 ·
