Master equation for Ornstein-Uhlenbeck process
  • Level: Graduate
  • Thread starter Thread starter cjolley
    Master Process
4 replies · 3K views · last reply
cjolley
Hi everybody...
I've been working through N.G. Van Kampen's "Stochastic Processes in Physics and Chemistry" and have run into something that has got me sort of stumped. He defines the Ornstein-Uhlenbeck process (a stationary, Gaussian, Markovian random process) in terms of the transition probability between two values [itex]y_{1}[/itex] and [itex]y_{2}[/itex] separated by a time t:
[itex]T_{t}(y_{2}|y_{1}) = (2π(1-e^{-2t})^{1/2}\exp(\frac{(y_{2}-y_{1}e^{-t})^{2}}{2(1-e^{-2t})})[/itex]
and the probability distribution
[itex]P_{1}(y_{1}) = (2π)^{-1/2}e^{-y_{1}^{2}/2}[/itex]
(This is pg. 83 if you have the book.)
A little bit later, he defines the master equation by expanding T[itex]_{t}(y_{2}|y_{1})[/itex] in powers of t and defining the coefficient of the linear term as [itex]W(y_{2}|y_{1})[/itex], the transition probability per unit time (pg. 96 if you have the book).
The thing that's got me stuck here is that, as t→0, T[itex]_{t}(y_{2}|y_{1})[/itex]→δ[itex](y_{2}-y_{1})[/itex], since T[itex]_{t}(y_{2}|y_{1})[/itex] is a Gaussian. I can't seem to come up with a reasonable way to expand this in terms of small t, which makes it difficult to define the master equation.
So... does anyone know how the Ornstein-Uhlenbeck process is formulated as a master equation? Any ideas would be greatly appreciated.
--craig
For small t, 1-e-2t ≈ 2t. This gives a Gaussian with variance ≈ 2t, which -> delta function as t -> 0.
Exactly. But that still doesn't tell me how to get a small-t expansion for [itex]y_{1} ≠ y_{2}[/itex], which is what I need for a meaningful transition rate.
The point is that [itex]y[/itex] is a random variable. I don't know that book, but what he finally should get at, I guess, is that the Fokker-Planck equation for the time evolution of the distribution function is equivalent to a Langevin equation, which is an ordinary stochastic differential equation with Gaussian-distributed (white) noise.
For a simple derivation (however for the relativistic case) see
http://fias.uni-frankfurt.de/~hees/publ/hq-qgp4-bibtex.pdf
p. 41ff.
e-t≈1-t, so y1-y2e-t≈y1-y2-ty2. The net result for the integrand as t -> 0 is δ( y1-y2)
