Material Derivative and Implicitly Given Variables for Velocity Calculation
  • Thread starter Thread starter member 428835
    Derivative Material
8 replies · 2K views
member 428835
Show ##DF/Dt=0##. ##F = x-a-e^b\sin(a+t)## and ##a## is given implicitly as ##y=b-e^b\cos(a+t)## where ##a=f(y,t)## and ##b## is a constant. Also, velocity is $$u=e^b\cos(a+t)\\v=e^b\sin(a+t)$$
##DF/Dt=F_t+v\cdot\nabla F##
##F_t = -e^b\cos(a+t)##
##v\cdot \nabla F = e^b\cos(a+t) \cdot 1 + e^b\sin(a+t) \cdot 0 = e^b\cos(a+t)##.
Then ##DF/Dt = -e^b\cos(a+t)+e^b\cos(a+t)=0##. Is this correct? It feels too easy.
Thanks!
So you're saying ##F_t=a'(t)-e^b\cos (a+t)\cdot (a'(t)+1)##. But then the convective term would also have the ##y## component, namely ##v\cdot (a'(y)-e^b\cos (a+t)\cdot a'(y)##?
Also, ##x## velocity is given by ##u=e^b\cos(a+t)##. Then ##a## was not differentiated for ##u=x'(t)##.
Sorry if this looks weird, I'm using the app for the first time and I can't see Tex output.
Orodruin, do you still think I should differentiate ##a## since they did not for the velocity term?
You make it sound as if the velocity was not given on the form you have quoted. My understanding of what you posted is that you were given the velocity.
I apologize for the ambiguity. So the particle's position is given by: $$x=a+e^b\sin(a+t)\\y=b-e^b\cos(a+t)$$ Then the velocity as in the first post, which is given in the question stem. Does this clarify my question?
Thanks for your patience!
Orodruin said:
Could you quote the problem statement verbatim?
Definitely. It follows:
A particle's flow path is described as
Thus the spatial velocity is
$$u=e^b\cos(a+t)\\v=e^b\sin(a+t)$$ Show that the kinematic boundary condition is satisfied along the curve derived from above by setting ##b=const## and ##a## is a parameter.
Hint: One could consider this curve to be $$x-a(y,t)-e^b\sin(a(y,t)+t)=0$$.
The kinematic boundary condition is ##DF/Dt=0## where ##F## is a curve of the boundary, presumably the hint's curve.
But ##u=\partial_tx##, and they did not implicitly differentiate ##a##, but treated it as a constant. If this is true for the time derivative, since ##a## is a functino of ##t## and ##y##, then ##D a/D t = 0##. Do you agree?
