Math proof: Linear Independence
In summary, to prove that a vector in a vector space V is linearly independent to a set of linearly independent vectors, one can use the axioms stated and either use a proof by contradiction or the contrapositive of the problem. This involves assuming that the vector cannot be written as a linear combination of the set of linearly independent vectors and using this assumption to arrive at a contradiction, or showing that if the vector is linearly dependent, it can be written as a linear combination of vectors in the set.
kregg34
How can I show that if a vector (in a vector space V) cannot be written as a linear combination of a linearly independent set of vectors (also in space V) then that vector is linearly independent to the set?
To really prove this rigorously it would make sense to use only the following axioms:
1)For every x,y in V, x+y is also in V.
2) (x+y)+z = x+(y+z) = x+y+z
3) 0 is in V, and 0+x = x for all x in V
4) All x in V have an inverse -x such that x+(-x)=0
5)For all scalars 'a' and 'b', a(bx) = (ab)x
6) For all x in V, 1x=x
7)For all scalars 'a' and 'b', (a+b)x = ax+bx
8)for all scalars 'a', a(x+y) = ax+ay
9)For all x in V, -x = (-1)x
10) A set of N linear independent vectors implies that if a linear combination of them is zero, then all the coefficients are zero.
I feel like I need to use a proof by contradiction, but not really sure how to start. This is actually my simplification of the true proof, and that is to prove that all vectors can be written as a linear combination of a basis set.
Firstly it's helpful to name the objects which you're dealing with. Say you have a vector ##v## and a set ##S = \{v_1,v_2, \ldots , v_n\}## of linear independent vectors ##v_i##. (With an infinite set things must be handled with a bit more care but the way is the same.) Next one usually assumes, that either ##v## can be written as linear combination of the ##v_i## and a contradiction is deduced, or one shows that all vectors ##v,v_1, \ldots v_n## are linear independent (see #10 in your list).
You could argue by contraposition. That is, instead of proving that ##p \implies q## you could prove that ##\neg q \implies \neg p##, since they are logically equivalent.
The contrapositive of your problem: If a vector is linearly dependent to a set of linearly independent vectors, then that vector can be written as a linear combination of vectors in the set.
There's also a proof by contradiction, where you assume that p is true and that q is false. If you arrive at a contradiction, then it must be true that ##p \implies q##.
The idea here is that ##\neg(p \wedge \neg q) \equiv p \implies q##
What is a math proof?
A math proof is a logical and systematic explanation that demonstrates the validity of a mathematical statement or theorem. It is used to show that a statement is true for all possible cases, using previously established mathematical principles.
What does it mean for vectors to be linearly independent?
Vectors are considered linearly independent if none of them can be expressed as a linear combination of the others. In other words, there is no way to multiply each vector by a scalar and add them together to get the zero vector.
How do you prove linear independence?
To prove linear independence, we need to show that the only solution to the equation c1v1 + c2v2 + ... + cnvn = 0 is when all the coefficients (c1, c2, ..., cn) are equal to zero. This can be done by setting up a system of equations and solving for the coefficients.
What is the significance of linear independence?
Linear independence is significant because it allows us to manipulate and study vectors more easily. When a set of vectors is linearly independent, we can accurately describe their relationships and use them to solve various problems in mathematics and other fields.
Can a set of vectors be both linearly independent and dependent?
No, a set of vectors can only be either linearly independent or linearly dependent. If a set of vectors is linearly dependent, then it is not linearly independent and vice versa. However, a set of vectors can contain subsets that are linearly independent while the entire set is linearly dependent.
