Mathematica bug? (Solving PDEs when the initial conditions contain a derivative)
8 replies · 4K views · last reply
zoltrix
hello
I own mathematica 10.02
it is virtually impossible to solve PDE's ,even with NDSolve,if the initial conditions contain a derivative
I write
Derivative[1,0] [0,x] == f[x]
I mean
the first t derivative of u[t,x] for x at t=0 is f[x]
I own a book based on Mathematica 10.3
Even if a carefully copy its examples I alwayes get error messages
Is it a mathematica 10.02 bug ? or what else ?
What error do you get?
Is your problem well-posed? Does it have a unique solution given the initial and boundary conditions?
hello
I own the book "mathematica and differential equations" by marian Muresan
I suppose that the problems are well posed and that they have an unique solutions
The author use the "superscript" notation for derivative but I get an error message
so I use the notation
apparently it is correct since it matches the author's " superscript" notation but
DSolve never return any answer
NDSolve sometimes works sometimes it does not
of course the solutions of the equations provided by the book are correct
I have mathematica 10.02 while the author used Mathematica 10.3
hello
Please have a look at the attached file
1) it is the original code of the book , delivering the correct solution
If I copy it, I get the error message
2) I replace the derivative in the initial condition
no answer from DSolve
3) Same as 2) but NDSolve
I get a partially correct solution
see the warning message
can you figure out what is going on ?
zoltrix said:
hello
probably it is a mathematica 10.02 bug which has been fixed in version 10.3
I down loaded mathematica 12.0 trial version
the examples from the book work well
There is no file.
Can you copy and paste the code, within code tags?
hello
Mathematica 10.02 does not answer with DSolve and I get a "warning" with NDSolve
Mathematica 12.0 works flawlessy
This is too hard to work with. If you copy and paste into your post, I can myself copy and paste into Mathematica.
a = 2; l = 2 π; c = 5; b = 2; h = 5;
f[x_] := Piecewise[{{h / (l - b) (x + l), -l ≤ x ≤ -b}, {h, -b ≤ x ≤ b}, {h / (l - b) (l - x), b ≤ x ≤ l}}]
g[x_] := Exp[-x^2]
eqncond = {∂t,t u[t, x] == a^2 ∂x,x u[t, x], u[0, x] == f[x], Derivative[1, 0][0, x] == g[x]};
sol = DSolve[eqncond, u, {t, x}] // Flatten
