Matlab and Mathematica can't do this integration
16 replies · 7K views
ay0034
Hello,
While doing a research, I obtained the following PDF:
[itex]f_{Z}[/itex][itex](z)=\frac{1}{2\pi\sigma^{2}_{1}\sigma^{2}_{2}}[/itex][itex]e^{-\frac{1}{2} ( \frac{\mu^{2}_{1}}{\sigma^{2}_{1}} + \frac{\mu^{2}_{2}}{\sigma^{2}_{2}})}[/itex][itex]\int^{2\pi}_{0}ze^{-\frac{1}{2\sigma^{2}_{1}\sigma^{2}_{2}}\{ \sigma^{2}_{2}z^{2}cos^{2}\theta+ \sigma^{2}_{1}z^{2}sin^{2}\theta-2\sigma^{2}_{2}\mu_{1}zcos\theta-2\sigma^{2}_{1}\mu_{2}zsin\theta \} }[/itex]
This integral won't be in a closed form. In addition to that, I have to integrate this PDF to get a CDF. Since this PDF is what I calculated, I want to check the CDF is going to be 1 as z goes to infinity.
However, both MATLAB and mathematica cannot integrate this PDF. Please help me with this annoying integration.
I appreciated it in advance.
mu's and sigma's can be any number. And in this case, mu1 and mu2 are different, and sig1 and sig2 are different as well.
If your interest is only [itex]\int_{-\infty}^{\infty} f_Z(z) dz[/itex] have you tried changing the order of integration?
Let [itex]h(z,\theta) =[/itex] the messy function you are dealing with.
Taking some liberties with limits and the order of integration, which you would need to justify, we have:
[tex]\int_{-\infty}^{\infty} f_Z(z)dz = \lim_{a \rightarrow \infty} \int_{-a}^{a} f_Z(z) dz[/tex]
[tex]= \lim_{a \rightarrow \infty} \int_{-a}^{a} \int_{0}^{2\pi} h(z,\theta) d\theta\ dz[/tex]
[tex]= \int_{0}^{2\pi} \left( \lim_{a \rightarrow \infty} \int_{-a}^{a} h(z,\theta)\ dz \right) \ d\theta[/tex]
Oh i forgot to put that. It's dtheta, not dz.
And I have tried what you are talking about, and I got no good results. Since the integration does not have a closed form, replacing it with a and using limit function was not helpful.
Both of them. With respect to theta and with respect to z.
Unfortunately, I can't. If so, my PDF would be a Rayleigh distribution and I can take advantage of existing information out there. That is my problem.
You're right. The thing is I have to integrate that error function with respect to theta. I almost gave up to do this double integration, and am trying to calculate mean and variance. But without a closed form PDF, that looks impossible as well.
I'm trying to relate this problem to your thread on "Chi or Rayleigh or Ricean?". It looks like you are transforming to polar coordinates by X = z cos(theta) , Y = z sin(theta). Does the z in front of the exponential come from the volume element for polar coordinate integration? If so, isn't this calculation for a CDF rather than a PDF ? (I'm just guessing about your intentions.)
Yes, the PDF I wrote down is already transformed to a polar coordinates. And z you referred to came from the fact that dxdy is transformed to r*drd[itex]\theta[/itex].
As you know, this is kind of a function of r.v., I began with a CDF, transformed it to a polar coordinates, and took derivative of the CDF with respect to z so I get a PDF.
Matlab can numerically calculate values of PDF at each point, but cannot integrate it numerically nor symbolically.
As far as I can see, your integrand is only the product of two normal distributions over x and y, i.e. a bivariate normal distribution with zero covariance. Why do you want to express this in polar coordinates? The integral from from z=0 to infinity will indeed be equal to one, of course very easily demonstrated in cartesian coordinates.
If you absolutely want to express it in polar coordinates, the expression will be quite simple (with simple analytical expressions for the primitive functions of integrals) if you set mu_1 and mu_2 as the centre of your polar coordinates.
ay0034 said:
...am trying to calculate mean and variance. But without a closed form PDF, that looks impossible as well.
Are you only after the mean and variance? In that case, I would not bother trying to calculate the distribution over Z, but just numerically evaluate the mean and variance of Z by integrating over X and Y (will work fine for any values of means and variances of the two normal distributions)
I didn't check the integrand, but if it does not have a closed form, and you want a numeric value then your alternatives are quadrature or simulation. The integral is one-dimensional? then Quadrature should work fine.
