MATLAB How Can You Handle Unassigned Outputs in Simulink's Embedded MATLAB Function?
In Simulink, when using the Embedded MATLAB Function, an issue arises when the output variable 'out' is not assigned a value for all possible execution paths. Specifically, if the input 'meas' is between 0 and 10, the function does not define 'out', leading to an error. To resolve this, it is necessary to include an 'else' clause to ensure 'out' has a defined value regardless of the input conditions. This ensures that the function always returns a valid output, addressing the concern of unassigned output in certain scenarios.
ilconformista
Hello everyone!
In Simulink , I use the Embedded MATLAB Function
function out = fcn(meas)
if meas>10
out = 4;
elseif meas<=0
out=2;
end
And I get this message:
Output argument 'out' is not assigned on some execution paths.
I would like the variable 'out' to change its value only if either of these conditions is true.
So I guess I have to give 'out' an initial value that is valid only for the first cycle of the program.
Does anyone know how I can do that?
Thanks!
What will the function return if meas is in 0<meas<=10? You have to specify an else with the if-else, because the variable would otherwise not be defined when the two conditions you have given are not satisfied, and the function would have nothing to return.
