MATLAB help: determining the area under a plot (not a curve whose form is known)
4 replies · 47K views
maverick280857
Hi
For a project (described https://www.physicsforums.com/showthread.php?t=227684"), I have to do the following for N images:
1. plot the histogram of each image, using
imhist(x)
2. plot a curvilinear approximation to the histogram, using
plot(imhist(x))
3. determine the area under the plot generated in step 2
4. Plot a curve of area value versus image number (index) and determine the image number for which the area value is a minimum.
I am not sure how to do step 3 and also whether steps 1 and 2 are correct.
Can someone please help?
Thanks and cheers
vivek
If step 2 is continuous then try the MATLAB command 'trapz'.
Go:
help trapz
in the MATLAB command window. Hopefully you can do:
trapz(imhist(x))
Should I do
trapz(imhist(x))
or
trapz(plot(imhist(x))
plot(imhist(x)) plots the histogram with the peaks joined by a not-so-smooth curve...
You should do:
trapz(imhist(x))
Now you say that plot(imhist(x)) plots a histogram with peaks joined by a curve? I assume you want the area under that curve? If that's the case I don't think trapz will help - you need to JUST plot the peaks and trapz will give the area under that curve.
