Matlab help with if conditional
  • Context: MATLAB
  • Thread starter Thread starter astronut555
    Conditional Matlab
The discussion centers on the use of the "if" conditional in MATLAB without a traditional test statement, specifically the syntax "if 0". This syntax effectively prevents the execution of the subsequent code block, in this case, the plotting command "figure; plot(times, average);". The practice is likely a debugging technique where the programmer initially used "if 1" to display the plot and later changed it to "if 0" to disable it without removing the code. This allows for easy reactivation of the plot by simply changing the condition.
  • Understanding of MATLAB programming syntax
  • Familiarity with conditional statements in programming
  • Basic knowledge of debugging techniques
  • Experience with plotting functions in MATLAB
  • Explore MATLAB conditional statements in depth
  • Learn about debugging techniques in MATLAB
  • Investigate the use of plotting functions in MATLAB
  • Study best practices for code commenting and version control
MATLAB programmers, software developers, and anyone interested in understanding conditional logic and debugging practices in MATLAB.
astronut555
Hello all,
I'm reading through some code that someone else wrote and have come across the following conditional:
if 0
end;
I've never seen if used without a statement to test (ie: if x>0...) and I can't find any documentation on it anywhere.
Anyone seen this before and know what it does?
Thanks!
Matlab's "if" command bases its decision on whether the next object is true or false, and this can be expressed also by 1 or 0. You are used to seeing an expression such as x>0, but this will evaluate to either true/1 (if the condition is true) or false/0 (otherwise). Your code might have had such a test at one time but it was replaced by 0 to force the plot command not to execute. Its possible the programmer added this plot during debug with a 1, then changed it to 0 when debug was over instead of removing the code. That way he/she can always reactivate the plot by changing one character.
makes sense, thanks!
