[MATLAB] Making code faster/more efficient
  • Thread starter Thread starter BrownianMan
    Code Matlab
10 replies · 3K views
BrownianMan
A is a sparse matrix. B is a vector. I have the following code:
Code:
for j=1:N
    B=A*B;
end;
This part of the code is inside a function which gets called about 160000 times. I ran the Profiler and this part is the bottleneck. How can I make it more efficient?
Does your A vary? If it is constant (or does not change every time), calculate A^n first.
Even it A is different every time, it might reduce the required time, as there could be special algorithms to calculate A^n more efficient.
Yes, A is constant.
I tried that. But the problem is that N is 200. So it actually takes more time to calculate A^N. I was wondering if there are more efficient ways to compute A^N. I tried using [v d]=eigs(A) and v*(d.^N)*v' but it said it wasn't able to find eigenvalues with sufficient accuracy.
BrownianMan said:
Yes, A is constant.
So A is only constant for each call of the function (it is different each time the function is called)?
Note that you can speed up exponentiation by taking advantage of some properties of exponents. Rather than repeatedly multiplying by A 200 times, there's nothing to prevent you forming A2 = A*A, then A4 = A2*A2, then A16 = A4*A4, and so on to carry out the bulk of the multiplications. Save appropriate intermediate results to have the right ones on hand: 200 = 128 + 64 + 8.
A depends on the inputs of the function, but inside the loop it does not change. For a given set of inputs, it is constant.
As far as taking advantage of properties of exponents, N is also an input. N=200 is what I am suppose to use to show that it gives the correct result for that specific N, but N can take on any integer value specified by the user. So I do not know N in advance.
Okay, but any N can be decomposed into a sum of powers of 2 in a similar fashion.
Is there a function that allows you to do that in Matlab?
Dunno. I'm not familiar with the Matlab function library. But it's the same as converting the decimal number N to binary. Each bit then represents a power of two.
Ok, I wrote a function to do that and then replaced the slow loop with this:
Code:
vec=sumPowersOf2(N); %vector of elements of powers of 2 that sum to N
AN=eye(N_space-1);
for i=1:numel(vec)
   AN=AN*A^vec(i);
end
But this is actually slower.
The idea would be to reuse already computed powers, not compute each power of two individually. For example, if you've already computed A^2 and you need A^4, take the already computed value of A^2 and multiply it by itself...
For A^200 you'd be looking at 200 = 2^7 + 2^6 + 2^3, so
a2 = A*A
a4 = a2*a2
a8 = a4*a4
a16 = a8*a8
a32 = a16*a16
a64 = a32*a32
a128 = a64*a64
Then A^200 is given by a8*a64*a128
So a total of 9 matrix multiplies. Yes, there will be a tradeoff in terms of space -- keeping around a lot of partial results which might be large matrices will up the memory usage. You might be able to reuse the temporary variables which are not required for the final calculation. So in the above, the a2 variable is not required after a4 is calculated, and a4 is not required again after a8 is calculated, and so on. Just hang onto the ones you need at the end: a8, a64, a128.
This should be quick:
N is stored as binary in your program anyway, for example as 11001000.
In addition, define two places to store matrices, which I call "power of A" and "result" here. Store A in "power of A" and 1 (the identity matrix) in "result".
Now, loop over the bits of N:
If the last bit is 1 (if 1 AND N is true, where AND is done bitwise), multiply "result" with "power of A". Otherwise, ignore that step.
Multiply "power of A" with "power of A".
Shift N by one bit (n=n/2, n>>1 or whatever MATLAB wants)
if N==0, quit, otherwise loop again
For N=200 as example, the results of the loop look like that:
N=11001000, "power of A"=A, "result"=1
(1 AND N)==0, do not change result, square "power of A", shift N...
N=1100100, "power of A"=A^2, "result"=1
... same as above
N=110010, "power of A"=A^4, "result"=1
N=11001, "power of A"=A^8, "result"=1
(1 AND N)==0, multiply "result" by "power of A", square "power of A", shift N...
N=1100, "power of A"=A^16, "result"=A^8
(1 AND N)==0, ...
N=110, "power of A"=A^32, "result"=A^8
N=11, "power of A"=A^64, "result"=A^8
N=1, "power of A"=A^128, "result"=A^72
N=0, "power of A"=A^256, "result"=A^200
Done. 10 non-trivial matrix multiplications required.
You can skip the last change of "power of A" with a bit more programming logic.
