MATLAB Using ode45 in a for Cycle: Adding Parameters to odefun
To run a for loop with ode45 in MATLAB while varying parameters in each iteration, it is necessary to pass additional input parameters to the odefun function. The standard ode function typically only accepts time (t) and state variables (y) as inputs. To include more parameters, one approach is to create a wrapper function that captures the additional parameters using nested functions or anonymous functions. This allows the odefun to access the varying parameters during each iteration of the loop, enabling the solution of the differential equation with different parameter values effectively.
bnsm
Hi guys,
I want to run a for cycle with ode45 inside. However, some parameters that I define in odefun (the differential equation in order to dy/dt, for instance) assume different values in each iteration of that cycle.
I find help examples showing odefun only receiving t and y... Is there any way to add more input parameters to odefun?
Thanks!
Anyone?... :smile:
