MATLAB Matlab question!
I need some help with matlab! not sure which function to use!
I think i should use xcount ycount so i can do it but i shall explain the problem!
I have input some variables in to matlab
p2=1e5
t2=288
p3=[2e5:1e4:10e5]
y=1.4
and now i wish to work out
t3is which should be:
t3is=t2*((p3/p2)^(y-1/y))
but that cant be done because you cant ^ a matrix!!
So could i use xcount to do it or what is the best way!
Thanks in advance!
Matlab Noob:confused:
chroot
Staff Emeritus
34
You can use the function 'arrayfun' to apply a function to each element of an array.
How about code like this?
Code:
p2=1e5
t2=288
p3=[2e5:1e4:10e5]
y=1.4
t3is = p3/p2
arrayfun(@(x) x^(y - 1/y), t3is)
t3is = t3is * t2;
The notation @(x) defines a new anonymous function that acts on x. In this case, all it does is raise x to the (y - 1/y) power.
You can, of course, combine all three of the last lines into one, if you prefer:
Code:
t3is = t2 * arrayfun(@(x) x^(y - 1/y), p3/p2)
- Warren
Alternatively you can vectorise all variables Since I have not used arrayfun before I do not know which is faster.
Code:
p3=[2e5:1e4:10e5];
p2=1e5*ones(size(p3));
t2=288*ones(size(p3));
y=1.4*ones(size(p3));
t3is=t2.*((p3./p2).^(y-ones(size(p3))./y));
The dots in front of the operators perform element by element operations between matrices of the same size. You don't need it for + or -. And I'm pretty sure you've found out this by now: putting semi-colons behind each line suppresses the outputs, keeping your command window neat and managable.
161
You can simply do this...
t2*((p3/p2).^(y-1/y))
if you want each element of (p3/p2) raised to the power (y-1/y).
Related Threads for: Matlab question!
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
