Determinant of Matrix: Quick Trick to Calculate Answer
  • Thread starter Thread starter Derill03
    Matrices
The discussion revolves around calculating the determinant of a given matrix using a co-factor expansion method. The matrix is structured in a way that allows for simplification, leading to the conclusion that the determinant equals 120, which is equivalent to 5!. The co-factor expansion is applied down the first column, where the determinant of the upper-triangular matrix formed from the remaining entries is calculated as the product of the diagonal elements. The method is confirmed through a detailed breakdown of the co-factor formula, illustrating how to derive the determinant effectively. This approach clarifies the relationship between the matrix structure and the determinant calculation.
Derill03
I have been given the following matrix and i am told there is a quick trick to getting the determinant:
0 1 2 3 4
0 0 2 3 4
0 0 0 3 4
0 0 0 0 4
5 4 3 2 1
I used my calculator and found out the answer is 120 which is 5!, but i am not sure what rule or reason the answer is 5!
Can ne one help?
Hint: Use a co-factor expansion down the first column and use the knowledge that the determinant of an upper-triangular matrix is the product of the entries on its diagonal.
I am not familiar with this can you help a little more?
My teacher never covered this principle of co-factor expansion
This is what i did can u confirm:
5*( 1 2 3 4) inside parenthesis is the 4x4 matrix
( 0 2 3 4)
( 0 0 3 4)
( 0 0 0 4)
which is 5*4*3*2*1 = 120
Let i be some row and let j be some column of a matrix A. To find the determinant of A, you can use a co-factor expansion across a row, and you would use the following formula for a fixed i and varying j. Or, you can use co-factor expansion down a column, where you fix a j and sum over all i's.
det(A) = \sumCij = \sum(-1)^{i+j}*(i,j)*det(Aij), where Aij denotes the matrix formed by removing the ith row and jth column from A; and, (i,j) denotes the entry in the ith row and jth column.
So, in this case, you would fix j at 1 and sum from i = 1 to i = 5.
det(A) = 0+0+0+0+5*det(A5,1) = 5*(1*2*3*4) = 120.
Is this clear?
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
