Max Allowable Deviation for Projectile Range of 50km
  • Thread starter Thread starter negation
    Projectile Range
5 replies · 2K views
negation
After a short engine firiing, an atmosphere-probing rocket reaches 4.6km/s. If the rocket must land within 50km of its launc site, what's the max allowable deviation from a vertical trajectory.
none
Given by the book:
x = (vi^2/g)sin 2Θ
50,000m = (vi^2/-9.8)sin 2Θ
sin2Θ = (gx/vi^2) = 0.0232
Again this is really frustrating, I take g = -9.8 and x = 50,000m, vi = 4600m/s
but I get -0.0232.
What is wrong here?
If I use a positive g, I get 0.0232 but that would be rubbish.
none
Given by the book:
x = (vi^2/g)sin 2Θ
but I get -0.0232.
What is wrong here?
Why would it be "rubbish"?
I suggest you check the derivation of the range formula. That should tell you why ##g## should be taken as a positive number (just the magnitude) here.
I understand how to derive the equation for the range formula. What I don't understand is that the g in the equation was not specified as a magnitude so why should I be using the magnitude and not the vector g?
So, in the derivation, what is the exact expression for the vertical position at time ##t##?
I have understood why g = 9.8 instead of -9.8ms^-2
Good. It is because the equation for the vertical displacement explicitly includes a negative sign before ##g##, i.e. ##\displaystyle y = v\sin\theta{t} -\frac{1}{2}gt^2##. Hence ##g## here refers to the magnitude only.
