Max Horizontal Force for Block-Wedge Problem
  • Thread starter Thread starter judas_priest
18 replies · 5K views
judas_priest
What is the maximum magnitude of a horizontal Force F that can be applied without causing the block to move up the incline?
Resolving F into it's components and writing down the equations
For x:
[itex]Fcos(theta) + μMgcos(theta) = Mg sin(theta)[/itex]
For y:
[itex]Fsin(theta) + mgcos(theta) = N[/itex]
Are the two equations correct? Because solving for F from this doesn't give me the correct answer.
Where am I going wrong?
Is the direction of Friction correct?
You should check the direction and magnitude of friction that you have used. Remember, friction requires the total normal force applied on the body.
Why is the friction force acting in the direction you think it's acting in? I've added normal force in my equation. Please reason your answers.
Static friction is written as [itex]\mu[/itex]N, where N is the total normal force on the body. You have written it as [itex]\mu[/itex]Mgcos(theta).
The direction is correct - I don't know why I asked you check the direction. I meant for you to check the magnitude. Also, does the question say anything about the surface of the wedge? It is possible that they meant for it to be frictionless.
Thanks, you made it clear. Actually, this is the second part of a problem It talks about friction in the first part.
Thank you!
Thank you!
I think your original expression had the friction in the wrong direction.
To clairify your thinking for me, if the block is about to move up the slope - ie you are at the maximum force asked for - what direction will friction be acting?
If we go on increasing the F from 0 to it's correct value, then the OP's direction of friction is correct in my opinion.
"What is the maximum magnitude of a horizontal Force F that can be applied without causing the block to move up the incline?"
means what force can be applied when the block is about to move up the slope.
What direction do you think friction will be acting in that case?
If F = 0, the block will (tend to) slide down the slope - friction acting up.
As we increase F, the friction force acting up the slope is reduced until we reach the situation where the block would stay there even on a frictionless slope.
As we increase F further, friction acts down the slope, preventing the block from slipping up the slope.
eventually F will become large enough that the friction is no longer sufficient, and the block will slide up the slope.
The question asks for the maximum F can reach before that slipping happens.
I thus think you are wrong.
For x:
For y:
The applied Force F has a component parallel to the slope (your direction x) which tends to make the block move up the slope, it also has a component perpendicular to the slope (your direction y or -y) which increases the Normal force over the usual Mgcos(θ). and that friction acts in a direction opposed to motion, so in the opposite direction for Fcos(θ) so should have the opposite sign to that term.
PeterO is right, the static friction opposes the effect of the applied force, to push the block up on the incline. Also, the maximum static friction is μN.
ehild
Yup, you're right!
Silly mistake.
I am having trouble understanding this - should the friction not increase due to increased normal force?
I too was doing it that way. But you're looking at it wrong. The force applied is trying to push the block up. They asked for the maximum force that can be applied before the box starts to move UP. Hence, the frictional force to oppose it from going up, points down.
Needs a little logic. Think for a while. You'll get there.
You are confusing the maximum possible friction, μN, and the actual friction force, which is only ever as big as it needs to be.
eg: 2kg block on a flat surface, μ = 0.3, and let's take g=10 for simplicity here.
μN = 0.3 x 2 x 10 = 6N. ie maximum possible friction is 6N.
If we apply a lateral force of 2N, friction will only be 2N and the block won't move.
Increase the lateral force to 4N, and friction will increase to 4N and the block still won't move
Increase the lateral force to 6N and the friction force increases to 6N and it still doesn't move.
Increase the lateral force further and finally you get some action.
On the slope of your problem, let's suppose the maximum friction available was just enough to stop the block sliding down the slope. The block will thus not move.
once we apply some horizontal force, there will be a component of that force acting up the slope, so although the maximum available friction force will have increased, the magnitude of friction needed will be less, so the friction will reduce.
If the applied force gets big enough, the component of applied Force acting up the slope matches the component of the weight force down the slope so no friction force is needed at all - despite the maximum available friction force being even larger than anything I have written about yet.
If the applied force gets even bigger, the component of applied force acting up the slope will exceed the component of the weight force, so the block will tend to slide up the slope, but the available friction may prevent that slip (by now the available friction is getting quite large)
eventually, if we continue increasing the applied force, the now greater friction force is still not able to prevent the block sliding, so away it goes.
Ah I get it now. Thank you for the great explanation Peter. Silly thinking on my part - apologies if I caused you any problems OP.
This is a corrected version with a minus sign:
"Resolving F into it's components and writing down the equations
For x:
Fcos(theta)-μMgcos(theta)=Mgsin(theta)
For y:
Fsin(theta)+mgcos(theta)=N"
May I ask how you can solve for F if you also have N? Two unknowns to my mind. I didn't get it. :(
For x:
For y:
As explained, the frictional force is not μMgcos(theta). It is μN. N is greater than Mgcos(theta) because F contributes to it, as shown in the second equation.
OK. I got it. Many thanks. :) :) :)
