Maximizing Vertical Height in Frictionless Rolling Motion on an Incline
A hollow sphere of mass M and radius R rolls down a frictional incline and reaches point O before continuing onto a frictionless curve. The conservation of energy principle is applied, where potential energy at height h is converted into kinetic energy as it rolls. The discussion emphasizes that the sphere's rotation contributes to its kinetic energy, which remains constant as it transitions to the frictionless section. The key equation used is mgh = 1/2 M W² + 1/2 MV², indicating that the height reached after point O can be determined by this energy conservation. The problem is resolved, confirming that the sphere's rotation does not change upon entering the frictionless curve.
John Kolby
A hollow sphere of mass M and radius R (I = 2MR2 /3) is released from rest at height h and rolls down a curved surface without slipping until it reaches the lowest point, O..
The curve to the right of O is frictionless. If the sphere continues past point O, what vertical height will it reach?
(In the diagram, the curve looks like a semi circle)
KEr = 1/2 M W2
KEl = 1/2MV2
According to my knowledge, if its frictionless and energy is conserved it should reach the same high.
mgh = 1/2 M W2 + 1/2MV2
**If I did something wrong I apologize, first time on this forum
KEr = 1/2 M W2
KEl = 1/2MV2
Hello John Kolby. Welcome to PF !
Does the rotation of the sphere change once it gets to the frictionless part of the curve?
Does its rotation correspond to some amount of kinetic energy?
I don't think the rotation changes. The rotation accounts to Kr which I account for with 1/2MW2
Solved it thank you!
I was thinking using 2 purple mattress samples, and taping them together, I do want other ideas though, the main guidelines are; Must have a volume LESS than 1600 cubic centimeters, and CAN'T exceed 25 cm in ANY direction. Must be LESS than 1 kg. NO parachutes. NO glue or Tape can touch the egg. MUST be able to take egg out in less than 1 minute. Grade A large eggs will be used.
