Maximum and Minimum Limits at Infinity Proof?
  • Context: Undergrad
  • Thread starter Thread starter Nebula
    Maximum Minimum
The discussion centers on proving that a continuous even function with limits at both negative and positive infinity equal to a constant \( l \) must have either a maximum or a minimum, provided it is not a constant function. The participants clarify that while the constant function \( f(x) = a \) meets the limit conditions, it does not possess a maximum or minimum. They establish that if \( f(x) \) is not constant, there exist points \( x_0 \), \( x_1 \), and \( x_2 \) such that \( f(x_0) > a \) and \( f(x_1) < f(x_0) \) for \( x_1 > x_0 \), and similarly for \( x_2 < x_0 \). This leads to the conclusion that the function must achieve both maximum and minimum values within the interval defined by \( [x_2, x_1] \).
  • Understanding of limits at infinity in calculus
  • Knowledge of continuous functions and their properties
  • Familiarity with the concept of even functions
  • Basic understanding of the Intermediate Value Theorem
  • Study the properties of continuous functions and their limits
  • Learn about the Intermediate Value Theorem and its applications
  • Explore the definitions and implications of even functions in calculus
  • Investigate rigorous proofs involving maximum and minimum values of functions
Mathematicians, calculus students, and educators seeking to deepen their understanding of limits, continuous functions, and optimization principles in real analysis.
Nebula
I'm frustrated beyond belief with a proof.
Suppose we have an continuous even function with a domain of all real numbers. Now this function has limit as x goes to negative infinty equal to l and the limit as x goes to positive infinty is also equal to l.
I want to show that this function will either have a maximum or a minimum.
I'm not sure at all how to show this rigorously since I don't know how to apply the definition of a limit to limits at infinity. I think it has to do with bounds. And I need to do this without first derivative test.
Aren't the specifications you give consistent with the constant function f(x) = 1?
Did you think my l was a 1. Maybe I should write it differently.
lim (x-> -oo) f(x) = lim (x-> oo) f(x) = a
and a is even.
Want to show f has either a minimum or a maximum.
intuitively this makes sense, but rigorously you could show that unless it is a consant function (for example y = 1) then there must be a point where it switches between a positive and negative slope. I am not entirely sure what level of "rigorousness" you want.
First, you still have the problem that was pointed out by both selfadjoint and T@p:
The constant function f(x)= a satisfies your conditions but does not have a maximum or minimum so the "theorem" as you stated it is not true.
If f(x) is NOT A CONSTANT FUNCTION, then there exist some x0 such that f(x0) is not equal to a and so is either larger than or less than a.
Assume f(x0)> a. Since limit as x-> infinity f(x)= a, there exist some x1> x0 such that f(x1)< f(x0).
Similarly, since limit as x-> -infinity f(x)= a, there exist some x2< x0 such that f(x2)< f(x0). Since f is continuous on the closed and bounded interval [x2, x1] it must have both maximum and minimum values there. Now show that f has a maximum on -infinity to infinity.
I need help. Find the minimum of y = Absolute value of (sinx + cosx + tanx + cotx +
secx + cscx) Thanks Ruth Jackson the_perfect_mom@hotmail.com
I think you need to add something about x1 here. Choose it in such a way that if x>x1 then f(x)<f(x0). Similar change with how you select x2.
  • · Replies 20 ·
12K
