Maximum magnetic field from moving charge
The discussion revolves around the magnetic field produced by a uniformly moving electric charge, specifically derived from the Lienard-Wiechert potentials. Participants explore the behavior of the magnetic field as a function of the charge's velocity, particularly questioning why the field does not continue to increase indefinitely with velocity.
  • Some participants note that an observer at a right angle to the charge's direction of travel sees a magnetic field proportional to ##\beta (1 - \beta^2)##, suggesting a maximum field at ##\beta = 1/\sqrt 3##.
  • Others express skepticism about the result, suggesting a need to verify it through field transformation laws and questioning its consistency with the Biot-Savart law.
  • One participant admits difficulty in reconciling their calculations with the field transformation approach and seeks assistance in identifying potential errors in their derivation.
  • Another participant introduces the concept of relativistic aberration, explaining that while the maximum field increases as ##\beta \to 1##, the direction of that maximum field becomes more collimated towards the direction of travel.
  • Further contributions provide mathematical expressions for the angle of the maximum field and its magnitude, noting that the magnitude increases without bound as ##\beta \to 1##.
  • Some participants discuss the implications of Steve Carlip's work on aberration and its relation to static fields, raising questions about potential contradictions in the interpretations of the results.
  • One participant references Heaviside's work and suggests that the magnetic field at a 90° angle is proportional to ##v/\sqrt{1-\beta^2}##, indicating a different perspective on the behavior of the magnetic field.
Participants exhibit multiple competing views regarding the behavior of the magnetic field produced by a moving charge. There is no consensus on the correctness of the initial claim or the implications of relativistic effects.
Some discussions highlight potential limitations in the assumptions made regarding the perpendicularity of vectors involved in the calculations, as well as the dependence on specific definitions and mathematical transformations.
KeeperOfKeys
Looking at the fields that result from a uniformly moving electric charge, derived from the Lienard-Wiechert potentials, you find that an observer at a right angle to the direction of travel will see a magnetic field proportional to ##\beta (1 - \beta^2)## suggesting a maximum field at ##\beta = 1/\sqrt 3##.
Can someone help me understand on an intuitive level why it doesn't continue to increase with velocity?
I haven't seen that result before, and I'm a bit suspicious of it, so the first think I'd do is verify it.
The E and B fields when combined properly form a tensor. That means you don't have to recompute the E and B fields when you change your frame of reference from a stationary to a moving one, you simply have to transform them. If you know the E and B fields at a point in one reference frame, you can find the E and B fields at the same point in another reference frame.
Wiki gives the transformation laws in http://en.wikipedia.org/w/index.php...gnetism_and_special_relativity&action=history, other sources should give equivalent laws. There's a tensor form of the law, but it may be easier to work with the non-tensor version.
Finding the perpendicular component of E and B in a frame stationary with the charge is easy, E points away from the charge, and B is zero. Applying the transform, I don't see how one would get the result you describe above.
Not being familiar with your result, my first impulse would be to look at it more closely. It's possible I've made some silly mistake,, though I think there are other reasons to suspect your result, I don't see how it could be consistent with the Biot-Savart law.
Hmmm, I’m having trouble spotting my error, but it seems my calculation from the LW potential doesn’t agree with the field transformation approach. I’ll be the first to admit my knowledge of relativistic EM is shaky.
I’ll walk through my derivation and maybe you can help me catch my mistake.
My starting point is here:
http://en.wikipedia.org/wiki/Liénard–Wiechert_potential#Equations
Specifically the equation for B
Right off the bat I drop the second term since I assume velocity is constant, leaving
## \mathbf{B}(\mathbf{r}, t) = \frac{\mu_0}{4 \pi} \left(\frac{q c(\boldsymbol{\beta} \times \mathbf{n})}{\gamma^2 (1-\mathbf{n} \cdot \boldsymbol{\beta})^3 |\mathbf{r} - \mathbf{r}_s|^2} \right)_{t_r} ##
I am going to assume ##\bf{n}## and ##\bf{\beta}## are perpendicular giving:
## \mathbf{B}(\mathbf{r}, t) = \frac{\mu_0}{4 \pi} \left(\frac{q c \beta}{\gamma^2 |\mathbf{r} - \mathbf{r}_s|^2} \right)_{t_r} ##
And, just to make life easier, I can choose my radius from the direction of travel to be small so ##t_r = t##
Express the ##\gamma## with ##\beta## and you get the offending result.
This was interesting, I had not been aware of this before, but I looked into the Lienard-Wiechert potentials in detail and found exactly what you described.
The effect is due to relativistic aberration. The maximum field increases without bound as ##\beta \to 1##, but the direction where that maximum field points becomes more and more tightly collimated towards the direction of travel. So if you fix the direction then you will get a speed beyond which the maximum field has "passed" and gone to a tighter angle.
For easy reference, the angle of the maximum field is:
$$\theta = \arccos \left( \frac{-1+\sqrt{1+24 \beta}}{4 \beta} \right)$$
which goes to 0 as ##\beta \to 1##
The magnitude of the magnetic field at that angle is:
$$\sqrt{\frac{512 \left(\beta ^2-1\right)^2 \left(-4 \beta ^2+\sqrt{24 \beta
^2+1}-1\right)}{\left(\sqrt{24 \beta ^2+1}-5\right)^6}}$$
Which increases without bound as ##\beta \to 1##.
I'm not postiive yet I'm not the one making a mistake ...
Are ##\bf{n}## and ##\bf{\beta}## perpendicular at the retarded time ##t_r##?
I.e suppose we use cartesian coordinates ##\bf{r} =## (x,y,z), with ##\hat{x},\hat{y},\hat{z}## being unit vectors pointing in the various spatial directions.. Let (beta) be a scalar and ##\bf{\beta}## be a vector. If we assume the motion is in the z direction, then we can write ##z =## (beta) t, and the vector value of ##\bf{\beta} ## will be (beta) ##\hat{z}##,
Now assuming we are trying to calculate the value of the B-field B at x=##x_0##, y=0,z=0, t=0 (did I understand the problem properly? Is this what we are trying to calculate?). Assuming this is what we're after, then ##t_r## will not be zero, it will be around but not quite ##-x_0/c##. Thus ##\bf{r}-\bf{rs}## will be in the ##\hat{x}## direction at t=0 and thus perpendicular to ##\beta## which is in the ##\hat{z}## direction, but at ##t=t_r## ##\bf{\beta}## and ##\bf{r}-\bf{rs}## won't be perpendicular. Note that ##\bf{n}## points in the direction of ##\bf{r}-\bf{rs}##, it's just normalized to unit length.
Steve Carlip showed in his paper "Aberration and the Speed of Gravity" (http://arxiv.org/abs/gr-qc/9909087) that the aberration effect cancels out for static fields like this one. Isn't that a contradiction?
No. Carlip showed that at each point the electric field points towards the non-retarded position of the source. He did not even calculate which direction had the maximum magnetic field magnitude. Conversely, I showed which direction had the maximum magnetic field magnitude. I did not even calculate the direction the electric field points.
My knowledge of this is a bit "rusty", but it looks rather suspect to me. And you even don't need to compare it with special relativity, just Heaviside will do (and SR agrees with his results). For 90° angle I find that B is proportional to ##v/\sqrt (1-\beta^2)##.
This was based on my textbook, directly from the equation for B. Compare also with for example:
https://en.wikipedia.org/wiki/Relativistic_electromagnetism#The_field_of_a_moving_point_charge
That description has an explanation for why there is no net aberration effect.
And from the equation there for E, using that B = v x E/c2 , I find again the above result.
But of course, I may also be mistaken! :p So I'll be gladly corrected too. :)
Working with the L-W fields is tricky, because of the retarded time. What is perpendicular at the retarded time, is not perpendicular now. For uniform velocity, a simpler direct equation for B is given in textbooks that results in ##B=qv/(r^2\sqrt{1-v^2})## for r perpendicular to v.
Note: I just noticed Harrylin's post. Everything he says is correct
  • · Replies 20 ·
  • · Replies 28 ·
  • · Replies 45 ·
9K
