Maximum mechanical actuator strength allowed by physics
6 replies · 2K views
jhami
What is the strongest actuator (that can exert a controlled amount of force & be able to start/stop linearly or rotationally) that an infinitely advanced civilization could create, and how (what object/process) would they do it? It must be non-lethal or be shielded to be non-lethal at a distance of a few cm and the size and mass must be macroscopic.
Very advanced optical tweezers can theoretically be stronger than mechanical actuators. You can theoretically tailor a material with individual molecules kept at "waist" of beams of different wavelength. This way you can move actuator at larger accelerations and press it harder than its mechanical strength allows, because force is applied to entire volume of actuator instead of just one end.
Well what is the limit of the strength of just a actuator (with human sized mass/size)
Mechanical actuator of human size can put roughly ~10 GN (1 million force-tons). Think of diamond anvils.
It would be rather slow though: positioning will require at ~100 microseconds to prevent shattering. Optical positioning can theoretically bypass speed limitations by arbitrary factor, although force limits is increased by no more than factor of 3.
Yes but that is with current technological limits. What is the maximum physical limit (e.g. only limited by the laws of physics) that a actuator that is human sized can have?
So, of course, you can provide those "laws of physics." Right?
