Maximum power in series-parallel circuit with resistor limits
  • Thread starter Thread starter kliker
    Circuits
kliker
[PLAIN]http://img258.imageshack.us/img258/9067/39943009.png
given this circuit if each of the resistors may consume maximum power = 24 W without overheating, find the maximum power that the circuit can consume
P = I*V
V=I*R
ok the first two are in parallel, so i found the resistance of both, which is 3/2, then we have two resistors in series and I found the total resistance which is 3/2 + 3 = 9/2
before doing this i found the I(total)
which is P = I*V => 24 = I^2*3 => I = +/- 4
having the I total and the total resistance I said
P = I^2*R = 16*9/2 = 72 W
but the book says 36, what am I doing wrong?
Thanks
You are wrong with your first statement. You said that the max. power consumption of a SINGLE resistor is 24W, but calculated a power consumption of a whole circuit.
My idea is as it follows:
1. P=I^2*R. Obviously the currency flowing through the resistor on the right will be the, khem, biggest (dunno what's the proper word in english :P). You should assume that it is 24W. It allows you to calculate the currency, and then everything else. Checked, gives 36W.
E: Due to the rules of the board I've deleted the exact solution :).
