MCNP Problem - Bad character in column 2
  • Thread starter Thread starter KOKI
    Error Mcnp
7 replies · 5K views
KOKI
TL;DR
hello , I am getting an error that reads as follows:
1 PX 12.5
bad trouble in imcn in routine ckchar
bad character, probably a control character, in column 2
1 PX 12.5
bad character, probably a control character, in column 2Cell cards
1 0 1 -2 -7 8 10 -9 imp: n=1
2 0 2 -3 -7 8 10 -9 imp: n=0
3 0 3 -4 -7 8 10 -9 imp: n=1
4 0 4 -5 -7 8 10 -9 imp: n=0
5 0 5 -6 -7 8 10 -9 imp: n=1
6 0 -14 #1 #2 #3 #4 #5 #7 imp: n=0
7 0 -11 -12 13 imp: n=1
8 0 14 imp:n=0c Surface cards
1 PX 12.5
2 PX 15
3 PX 15.05
4 PX 16.05
5 PX 16.1
6 PX 21.1
7 PY 5
8 PY -5
9 PZ 5
10 PZ -5
11 CX 0.5
12 PX 0
13 PX -1
14 SO 30
Try attaching your input file, you will need to rename it to add .txt at the end.
How are you editing it? With a simple text editor?
This is usually a formatting char problem.
The error is that you are using tabs instead of spaces. This code is descended from things written in the 1970's, on mainframes, in FORTRAN, by physicists. Some aspects are not very flexible.
A second problem is that the gap between the cell cards and the surface cards needs to be a single blank line. The gap between the surface cards and the data/source section also needs a blank line but more may not matter. The extra blank lines in that section may also be fine, without trying it I'm not sure, but normally that is not done.
I tried but I find the same problem
What does "tried" mean here? Did you replace the tabs with ordinary space characters? Did you make sure there was exactly one blank line between cells and surfaces, exactly one blank line between surfaces and data, and no other blank lines?
Sometimes the name of your input file create problems, do not put any space in your input file . such as you can write mcnpcode.txt but you cannot write mcnp code.txt .. The input file that you run dislikes any space between it. And try to make your input file as short as possible. I am a victim of that kind of error .
