PeterDonis
Mentor
- 50,104
- 26,128
PWiz said:If the coefficients are independent of theta, phi and t, then things should look unchanged if we flip the sign of any of these coordinates. So such a metric should exhibits PT symmetry.
And T symmetry, and P symmetry. PT symmetry is a weaker condition than P or T symmetry; PT only means invariance if P and T are both applied, but not necessarily if either one is applied individually. P symmetry means symmetry if just P is applied; T symmetry means symmetry if just T is applied.
PWiz said:If a diagonal metric employs the same coordinates but the coefficients are only independent of t, then the metric should show T symmetry.
Yes, but not P symmetry. It might still show PT symmetry.
PWiz said:Could one explore this chain of reasoning onto non-diagonal metrics?
Yes, by looking at which non-diagonal terms are present. For example, in Kerr spacetime (in appropriate coordinates), there is only one non-diagonal term, and it is a term in ##dt d \phi##. So reversing the sign of both ##t## and ##\phi## (which a PT transformation does) leaves the metric invariant. But reversing ##t## or ##\phi## individually (i.e., P alone or T alone) does not. (You also have to look at the metric coefficients, of course; in Kerr spacetime those are all functions of ##r## and ##\theta## only, not ##t## or ##\phi##.)
