Measurement of Lx: Result of Measurement?
  • Thread starter Thread starter Physgeek64
    Measurement
The discussion revolves around measuring the operator L_x for a given wave function ψ = zf(r). The participants note that L_x can be expressed using the ladder operators L_+ and L_-, and they derive that L_x |ψ> results in a state proportional to |1,1>. However, they express uncertainty about determining the actual measurement outcome, emphasizing the need for eigenvalue equations. It is suggested that to find the expected value of L_x, one must use its differential form and integrate the wave function appropriately. Ultimately, while the expected value may be zero, the outcome of an individual measurement could differ and requires proper integration of the wave function with the operator.
Physgeek64
If we have a wave function ##\psi =zf(r)## and we take a measurement of ##L_x## what is the result of the measurement?
So i know we can write ##L_x=\frac{1}{2}(L_+ + L_- )## and that ##|\psi > = g(r) |1,0> ## so ##L_x |\psi >= \frac{1}{2} \sqrt{2} g(r) |1,1>##. But i don't know what the measurement would be because this has to be an eigenvalue equation to read off the result of a measurement (I think?).
Many thanks!
Physgeek64 said:
So i know we can write Lx=12(L++L−)Lx=12(L++L−)L_x=\frac{1}{2}(L_+ + L_- ) and that |ψ>=g(r)|1,0>|ψ>=g(r)|1,0>|\psi > = g(r) |1,0> so Lx|ψ>=12√2g(r)|1,1>Lx|ψ>=122g(r)|1,1>L_x |\psi >= \frac{1}{2} \sqrt{2} g(r) |1,1>. But i don't know what the measurement would be because this has to be an eigenvalue equation to read off the result of a measurement (I think?).
Many thanks!
you have a given wave function which is a function of r and theta only
if you wish to find expected value of L(x) then one must use differential form of the operator L(x)
But how do i find the result of a measurement. I can show that the expected value is zero, but i don't know what the outcome of an individual measurement would be.
In QM the measurement is defined with the help of wave function
say you have a position wavefunction then you can measure x-operator
as {Psi * (x )Psi }integrated over the whole space.
similarly L(x) is a operator which is represented in (r,theta, phi) space .
put the complex conjugate of the wave function on the left and psi on the right and L(x) in between and integrate over whole space .
the result will give you measurement and it may not be zero.
  • · Replies 17 ·
