Mentor
- 50,874
- 26,886
That's a common way of doing it, and the way it is usually explained in textbooks, but it is not the only way of detecting that spacetime curvature is present. Anything that shows a nonzero Riemann tensor is sufficient.PAllen said:To measure geodesic deviation or focusing, you start with initially parallel geodesics and see whether they diverge or converge after this.
And with decelerated expansion, a geodesic initially 4-orthogonal to the spacelike geodesic extended 4-orthogonally to a reference comoving observer will converge (another version of a tethered galaxy scenario that was discussed in a recent thread). So either way we have nonzero tidal force--it's just divergence in one case and convergence in the other.PAllen said:The tidal force arises because, with accelerated expansion, a geodesic initially 4-orthogonal to the spacelike geodesic extended 4-orthogonally to a reference comoving observer will diverge
Some physicists would object to calling this "tidal force" on the grounds that that term should only be used for Weyl curvature, which is zero in both cases--all of the spacetime curvature is Ricci curvature. I don't personally agree with that objection.
I disagree: "recession from initial conditions" cannot explain either acceleration or deceleration. The only case where "recession from initial conditions" explains the entire motion is the Milne universe, since that is just flat Minkowski spacetime in disguise and there is zero spacetime curvature.PAllen said:Having comoving observers on both ends does not measure curvature efffects at all - it is totally dominated by recession from initial conditions.
I don't think "perfect analogy" is a good term to use, because I disagree with your claim that the relative motion of comoving observers does not measure curvature effects; see above.PAllen said:No, there is a perfect analogy.
I do understand the general scenario you want to set up: you have a reference object which is comoving, you take a spacelike geodesic orthogonal to its worldline and extend it for some fixed proper distance, and you put a test object at the other end. You are comparing two possible choices for what state of motion to put the test object in: "comoving" vs. "orthogonal". So consider the following:
The spacelike geodesic in question does not lie in a single spacelike hypersurface of constant comoving time (i.e., a surface of constant FRW coordinate time). In fact, the FRW coordinate time at the test object end of the spacelike geodesic is earlier than the FRW coordinate time at the reference object end.
This means that, if we consider the relative velocity of the two possible test objects at the other end of the spacelike geodesic, the "comoving" and "orthogonal" ones, it will not necessarily be the same as the peculiar velocity of a test object at rest relative to the reference object at the same proper distance in a spacelike hypersurface of constant FRW coordinate time. (Btw, I think this means that the formula given in the OP from Peebles is not exactly correct for the cases being considered, since I think that formula assumes that everything is evaluated at the same FRW coordinate time.) In fact, if we call the two velocities ##v_r## (relative velocity of test object at the end of the orthogonal spacelike geodesic with proper length ##D##) and ##v_p## (peculiar velocity of test object at relative rest at distance ##D## in constant FRW coordinate time surface), we can distinguish [Edit: crossed out part that is not correct; see post #34 below]
(1) ##v_r < v_p##: this indicates accelerating expansion.
(2) ##v_r = v_p##: this indicates the Milne universe.
(3) ##v_r > v_p##: this indicates decelerating expansion.
In other words, (2) is what you would expect if "recession from initial conditions" were the only effect present. So if you have (1) or (3) instead, you know that spacetime curvature is present.
These three cases also correspond to the
(1) Cable is under tension (this is the case described in the OP of this thread);
(2) Cable/rod has zero stress/strain;
(3) Rod (a better term than "cable" for this case) is under compression.
As I understand it, you are using these last three effects to distinguish the cases.
