Measuring Frequency of stroboscope/strobe light
2 replies · 6K views
crazycaddy
I want to know how to measure the frequency of a stroboscope by using an LDR and picoscope, but I'm not sure what circuit I should make up with the LDR in order for picoscope to show the frequency.
I thought connecting the LDR straight to the picoscope would do, but my teacher said it wouldn't work.
Connect the LDR in series with a resistor, across the supply. As the resistance of the LDR changes, the voltage at the junction of the LDR and the resistor will vary. This signal you can put into another instrument.
Code:
---------------------------- + 5V
               x
               x  <- LDR
               x
               o-------------- > signal
               x
               x  <- resistor
               x
--------------------------------- GND
Look up the data sheet for your LDR to find out what its "dark" and "light" resistance is, and what the safe voltage and current limits are. Then choose a suitable value of the fixed resistor. If the resistance is too small or too big, you won't get much change of voltage across it.
BTW 5V seems a reasonable guess for a safe supply voltage, but checking the facts is always better than guessing.
