Measuring pH on metallic planar surface
This discussion focuses on measuring pH levels on metallic planar surfaces, particularly in the context of corrosion studies. Participants explore the feasibility of using sensor probes on both dry and wet surfaces, emphasizing the need for precision in measurements. Recommendations include using indicators in conjunction with a spectrophotometer for prolonged use, with the choice of indicator dependent on the specific pH range of interest. The conversation highlights the importance of selecting appropriate tools for accurate pH measurement in challenging environments.
  • Understanding of pH measurement techniques
  • Familiarity with spectrophotometry
  • Knowledge of corrosion science
  • Experience with chemical indicators
  • Research suitable pH sensor probes for metallic surfaces
  • Explore long-term chemical indicators for pH measurement
  • Learn about the principles of spectrophotometry in pH analysis
  • Investigate the effects of protective layers on pH readings
Researchers in materials science, corrosion engineers, and laboratory technicians involved in pH measurement and analysis on metallic surfaces.
Patrick Rota
We are currently trying to measure pH levels on the (wet) surface of metals as part of a study about corrosion.
The surface may have a non-conductive protective layer.
- is it feasible to measure pH on a planar surface (dry or wet)? Which kind of sensor probe can be used for this task?
- which order of magnitude will be the measure? (precision of the sensor)
Any advice would be greatly appreciated!
Chemistry news on Phys.org
My first thought would be to use and indicator in combination with a spectrophotometer.
Thank you DrDu, this is a great idea, indeed.
Can you recommend some indicator? Do you have suggestions?
EDIT: we need an indicator for prolonged use (years), if it exists
The choice of the indicator will depend on the pH range you are interested in.
Dear DrDu, thank you for your insight. Let me find out what is the pH forecast range.
  • · Replies 16 ·
  • · Replies 19 ·
