Measuring pH on metallic planar surface
4 replies · 2K views
Patrick Rota
We are currently trying to measure pH levels on the (wet) surface of metals as part of a study about corrosion.
The surface may have a non-conductive protective layer.
- is it feasible to measure pH on a planar surface (dry or wet)? Which kind of sensor probe can be used for this task?
- which order of magnitude will be the measure? (precision of the sensor)
Any advice would be greatly appreciated!
Chemistry news on Phys.org
My first thought would be to use and indicator in combination with a spectrophotometer.
Thank you DrDu, this is a great idea, indeed.
Can you recommend some indicator? Do you have suggestions?
EDIT: we need an indicator for prolonged use (years), if it exists
The choice of the indicator will depend on the pH range you are interested in.
Dear DrDu, thank you for your insight. Let me find out what is the pH forecast range.
