Mechanical Energy Problem/non-conservative forces
1 reply · 2K views
fuvest
A body of mass "m" is let go from on top of a surface A, where it slides down to B(without friction). From that point on, it displaces itself on an horizontal surface 5 meters away from B, where it stops at C.
Being "m" a mass in kg
"h" in meters and g = 10 m/s^2
The value, in Newtons, of the constant friction force F when the body dislocates itself is:
Ei = Ef
W = F.d
My attempt was to set the change in kinetic energy equal to the total work. So therefore:
1/2mv^2 - mgh(converted from gravitational potential energy) = Tf
at the very end, velocity will be zero because it stops so:
-mgh = Tf
replacing the work done by friction:
-mgh = -F.5
.'. F = (10mh)/5 = 2mh
Is this approach correct? Would you guys suggest another one? Is another possible?
Thanks
Looks fine. Not sure about some of the signs, but since you have not stated your sign convention they may be fine.
For what it's worth, it is very poor style to specify that a variable represents the numerical value of a physical quantity when expressed in certain units ("m being a mass in kg..."). It would have been better to statethe horizontal distance as another unknown, s say, and not mention units at all. The answer would then have been mgh/s.
