Mechanical guy needs help with endothermic reaction and heat decomposition
The discussion revolves around finding a suitable material to protect components from high heat during a two-phase thermal exposure, specifically focusing on the challenges posed by prolonged exposure to 85°C followed by a brief exposure to temperatures exceeding 500°C. Participants explore various materials and insulation strategies to maintain component temperatures below 100°C.
  • Experimental/applied
  • One participant suggests sodium bicarbonate but expresses concern about its effectiveness after prolonged exposure to 85°C.
  • Another participant questions the specifics of the thermal loads, including the duration of exposure and the need for active cooling.
  • Concerns are raised about the suitability of materials for both the extended heat soak and the extreme heat phase, with questions about the atmosphere during exposure.
  • Some participants propose using internal fiber or foam insulation that can withstand high temperatures, along with metal shielding for passive protection.
  • Multi-Layer Insulation (MLI) is mentioned, but one participant doubts its effectiveness in the given atmospheric conditions and high temperatures.
  • Suggestions include using materials like sand, borosilicate glass beads, or asbestos for thermal resistance and mass to delay heat flow to critical components.
  • Testing with thermocouples is recommended to assess the effectiveness of proposed solutions.
Participants express a range of opinions on the best materials and methods for thermal protection, with no consensus reached on a single solution. Multiple competing views remain regarding the effectiveness of different insulation strategies and materials.
Participants note limitations related to the unknown atmosphere during the high-temperature exposure and the specific mechanical requirements of the components being protected. There is also uncertainty regarding the long-term effects of the proposed materials under the specified conditions.
This discussion may be useful for engineers and researchers involved in thermal protection systems, materials science, and those working on projects requiring high-temperature component protection.
sanchel
How did you find PF?: Google
I am working on a project that requires us to protect components from high heat. We were thinking on using sodium bicarbonate, but our module needs to be exposed FIRST to 85C for long periods.... then the high heat exposure will be present. We believe this bicarbonate will be "depleted" after some weeks of exposure to 85C, so we need to use something that will decompose or collect heat at around 100C or just a little higher.... but not much higher than this. We need this compound or material to be a solid of some kind.
Google gave me some ideas, but the residues generated after heat exposure were acids or compounds that I would prefer not to have in my module. Sodium Bicarbonate was great.... but this 85C requirement is killing the idea. Do you have any suggestions? Thanks to all.
Welcome to PF! Got a few important questions to help us understand what's going on better, and the kinds of thermal loads we're talking about...
-What's the rough timeframe for the 85C exposure?
-How hot does it get at its peak, and for how long?
-What kind of temperature ramping schedule are you looking at?
-Can you use active cooling of any sort?
-What kind of components are you protecting?
Flyboy,
Thanks. Here are some answers:
-The module will be exposed to 85C for about 30+ days
-The sample is then exposed to 500C + for 1/2 hour. The sample leaves on chamber and goes to the high heat without any ramping
-No active cooling
-The end item to protect will be encased either on a ceramic or an epoxy.
I am sorry that I cannot share more, but I would prefer not to disclose more details. The 30+days more likely are going to be a problem for the baking soda.... so we just want to replace it with another material... if there is one that could do the job....baking soda was working for the 500C+ fine....
Whistles
That is a looooong dwell time at 85°C. If you’re looking for a sacrificial coating for the high temp cycle, that’s definitely more of a chemistry/materials science question than a mechanical one. If it’s not meant to be sacrificial, then a few more questions:
-Is the area needing protection able to withstand that extended heat soak at 85°C, and only needs protection from the 1/2 hour of extreme heat?
-Is the high temperature section in a neutral or reducing atmosphere?
-Is there any articulation required in the area needing protection?
But you can give us more information. If I understand your posts so far, you have an object of approximate dimensions X cm by Y cm by Z cm. That object is heat soaked at 85C for 30 days, then at 500C for 1/2 hour. Components inside the object must be kept below 100C to 110C.
If that correctly summarizes your problem, then we need more information. What is the approximate size, mass, and specific heat of the components to be protected? Is there space for thermal insulation and/or thermal mass between the object and the components?
IMHO, internal fiber or foam insulation that can resist 500°C, and metal shielding from radiation are your best friends for passive protection of your components from high heat.
Research what it is used for protection of satellites' components from Sun radiation.
You’re thinking of Multi-Layer Insulation, which does wonders for radiant heat. But from my understanding of the situation, it’s going to be in an atmosphere, composition unknown, at elevated temperature for a month. MLI doesn’t solve the issue there, and I suspect that it’s going to be destroyed in the 500°C phase.
As for the fiber insulation… that might actually be more viable. Part of why I’m asking about any need for mechanical movement in the affected are is to figure out what kind of insulation is viable. If no movement is needed… I would argue something akin to the
LI-900 insulation in the shuttle tiles would work. Maybe not exactly that material, but something similar to it.
Movement significantly complicates things and would require a fabric type insulation.
You need enough thermal resistance and thermal mass to delay the heat flow to your critical components for that 1/2 hour.
Sand or borosilicate glass beads or asbestos fiber or asbestos bricks. The looser the packing the better... up tp some limit. Loose enough to minimize conduction but avoid free convection.
I recommend some testing with a thermocouple in place of your critical components.
Cheers,
Tom
Thanks to all. I will try some of these.....
  • · Replies 21 ·
9K
11K
