Mechanical gyroscopes -- still used in airplanes?
Mechanical gyroscopes, specifically traditional spinning wheel types, have largely been replaced in modern aviation by Fiber Optic Gyroscopes (FOGs) and Micro-Electro-Mechanical Systems (MEMS) gyros. While older aircraft still utilize mechanical gyros, particularly in "steam gauge" instruments, the trend has shifted towards Electronic Flight Information Systems (EFIS) that employ Attitude Heading Reference Systems (AHRS) using MEMS technology. High-end EFIS systems utilize ring-laser gyros for enhanced performance. The transition from mechanical to electronic systems has been ongoing for the past two decades.
  • Understanding of Fiber Optic Gyroscopes (FOGs)
  • Familiarity with Micro-Electro-Mechanical Systems (MEMS) gyros
  • Knowledge of Electronic Flight Information Systems (EFIS)
  • Basic concepts of gyroscopic principles in aviation
  • Research the operational principles of Fiber Optic Gyroscopes (FOGs)
  • Learn about the design and functionality of Micro-Electro-Mechanical Systems (MEMS) gyros
  • Explore the architecture and advantages of Electronic Flight Information Systems (EFIS)
  • Investigate the historical use and evolution of mechanical gyros in aviation
Aerospace engineers, avionics technicians, and aviation enthusiasts interested in the evolution of gyroscopic technology in aircraft instrumentation.
Abokoj
I was a bit unsure where to post this, but this one seemed fitting enough.
I was wondering about the state of gyros in airplanes, like which type is being used today.
Are they all optik/fiber-based or are there mechanical gyroscopes at work. (By mechanical i mean the standard spinning wheel, not sure if it's the right definition. If there aren't when were they last used). I also know of the MEMS gyros but they don't seem quite in the airplane industry yet.
So yeah, I'd appreciate some clarification some example for a gyro would be great. Thanks
I believe that most mechanical gyros have been replaced by FOGs over the last 20 years.
Triaxial FOGs are available as a gyrocompass on ships to determine true north from sensing the Earth's rotation.
Older aircraft with "conventional" flight instruments (referred to in aviation, somewhat pejoratively, as "steam gauges") use mechanical gyros. This is still fairly common in single-engine and light twin-engine aircraft -- although it is becoming less so. Low-end Electronic Flight Information Systems (EFIS -- often referred to as "glass-cockpit") use an architecture called an "Attitude Heading Reference Systems" (AHRS - pronounced AE-hars), which uses MEMS gyros. High-end EFIS equipment uses ring-laser gyros. I haven't heard of FOGs being used in aircraft, but it's possible they are.
If you ever have a chance to fly up front in an aircraft that has steam gauges, when electric power is applied before engine start, you can hear a whining noise. That's the turn coordinator or turn & slip gyro spooling up. You won't hear the attitude indicator or directional gyro spool up because they are usually vacuum driven and require the engine to be running.
  • · Replies 19 ·
