DBBPhysics
- Messages
- 10
- Reaction score
- 2
- TL;DR
- Connect a 3 strand line to anchor chain either by weaving the line into the chain or putting the line through the 1st link and then weaving the line into itself.
This question is about splicing a 3 strand line to a chain rode on an anchor on a boat. There’s two ways under consideration. One is simply weaving the three strands into the rings of the chain for about 12”. With this approach, the weave connects the line to the chain and a force of x lbs on the anchor translates to a force of x lbs on the line or 1/3 of x for each strand.
A second way of doing it is to put two strands through the first link with those two strands doubling back toward the line. (Since a third strand will not fit in the link with two other ones, the 3rd strand just joins the other two going toward the line) The three strands are now weaved into the line, back towards the boat. The benefit of this is that the chain and line easily go through the windlass (winch) unobstructed whereas with the previous design, the chain links are widened by the line woven into the links and therefore can get hung up in the windlass. Now, there are four lines going backwards toward the boat, I.e. two going up to the chain link and two going backward.
So now, load x is supported at the chain link by 4 strands and therefore each strand carries 1/4 x lbs - a lower value than the previous design. Therefore this last design is the better one since it will hold a higher x before breaking at the splice. Of course at the end of the weave going toward the boat, there are only 3 strands so the line before the splice will break first.
That theory seems plausibly correct, however when one looks at the latter design, it looks like there are only two strands connecting the line to the chain instead of 3 strands and that gives reason to pause. I’d like to use the trimmer design in order to go through the windlass easier but I don’t trust it. Is there anything wrong with my logic?
